Old 05-25-2010, 01:48 PM   #1
daddybooz
daddybooz's Avatar
Newbie and a 3 tree tranny help?
Hi guys,
Great site, been reading for months time to get dirty now!
Have a 3 speed, 3 on tree tranny converted to a Hurst Floor Shifter. It has a leak along with motor and rear pinion seal and in process of fixing so I can drive it some this summer!
Anyway, been reading, etc. but just cant get my finger on what kind of tranny it is? I would like to get a pic of the parts, manual, whatever before I tackle it.
Assuming that if I can find out what kind it is, I then can google a parts lists, pic or whatever, maybe or not?
Any help will be appreciated, thanks!
Robert
DaddyBooz
'68 C10 LWB
KCP 406; 400 small block, 30 over, alum heads built by Kurt Clapper
Ceramic center dumps, custom 2 1/2" SS all the way back w/MagnaFlows
2"/4" drop on 15's
daddybooz is offline   Reply With Quote
Old 05-25-2010, 04:50 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Newbie and a 3 tree tranny help?
If it's a synchronized 1st gear trans it's a Saginaw.
To answer the synchro issue, you'll know if it's synchro or not the first time you have to downshift into 1st. Non synchro boxes require you to come to a complete stop prior to dropping into 1st to avoid grinding.
Old 05-25-2010, 05:27 PM   #3
frog trucker
frog trucker's Avatar
Location: Smack-dab in the middle of "The land of fruits and nuts", Sacramento, CA
Originally Posted by daddybooz View Post
. . . but just cant get my finger on what kind of tranny it is? I would like to get a pic of the parts, manual, whatever before I tackle it.
Robert
Hello Robert and welcome! Check this link and click on the page that says "Transmission I.D." http://www.hurst-shifters.com/faq/Information-Diagrams
Hope this helps!
frog trucker is offline   Reply With Quote
Old 05-25-2010, 10:22 PM   #4
daddybooz
daddybooz's Avatar
Thanks for the info!
Tx, with the little that I've driven it I havent had to come to a stop to get it into 1st so I'll compare it to the pic on Frog's link. I'll print that out and compare the next time I'm in the shop! Coaching out two boys in baseball hasnt left me much shop time lately!!
Regardless, this is more info than what I've found so far.
Thanks again guys, awesome!
DaddyBooz
'68 C10 LWB
2"/4" drop on 15's
Old 05-26-2010, 01:12 AM   #5
frog trucker
FYI, I just replaced the front bearing retainer, seals, and gaskets in my Saginaw 3-speed trans . . . I purchased the parts from http://www.garagemotorsports.com/
Scott is very helpful, had the parts in stock, shipped FAST, and gave me a better deal than my local transmission shops!
Old 06-07-2010, 04:02 PM   #6
daddybooz
daddybooz's Avatar
Hi guys, again.
I got to cleaning my tranny up, and was looking at the info Tx and Frog offered. I took some photos and hopefully they load up, but I dont think this is a sag. The PO installed a 305 from a late 80's camaro/impala, is this possibly that tranny and not the original? Take a look and tell me your thoughts?
Thanks again, Robert
DaddyBooz
'68 C10 LWB
2"/4" drop on 15's
Old 06-07-2010, 04:33 PM   #7
jhwkns
Registered Cruiser
jhwkns's Avatar
looks like a muncie
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 06-07-2010, 06:07 PM   #8
raycow
You got a good one there. That's a SM330 heavy duty 3 speed. It was the standard 3 speed that came behind a big block and it was optional with smaller engines in some of the trucks. I don't think it was ever offered with a 305 in a car though.
Ray
raycow is offline   Reply With Quote
Old 06-08-2010, 03:17 AM   #9
frog trucker
It sure looks different than my Saginaw three-speed! I found out that mine WAS from a car . . . the front bearing retainer measured 4 5/8" . . . that's too small for a truck bellhousing! Check your bellhousing . . . a truck b/h should be 5 1/8" and the trans should match. That keeps the input shaft, clutch, and everything centered.
