05-25-2010, 01:49 PM | #1 |
What changes to swap a LQ4 engine in a '83
I'm sure someone on here has done this.
I know that I'm going to have to get a electronic MSD box instead of the distributor, another intake manifold to fit a carb, and what else? What is going to fit or not fit, and what would I have to keep in mind before making this switch from a 350 to a LQ4? |
05-25-2010, 02:18 PM | #2 |
Truck and auto performance nut
Re: What changes to swap a LQ4 engine in a '83
When ever you modify things...it effects other components. There are several here that have doen the swap tho.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
05-25-2010, 03:24 PM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
Why go with a carb, it is about the same $ to use the FI and it will probably get a little better mileage.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-25-2010, 08:13 PM | #4 |
BAD BOW-Silverado XST
05-25-2010, 11:14 PM | #5 |
You will also need motor mount plates, some kind of header. The factory manifolds hit the frame on passenger side. The only header in perduction is S&P at 600 bucks. This is a dyno test with 4 cams. And each is ran with carb and with EFI. Just about the same power. http://www.hotrod.com/techarticles/e...est/index.html
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
05-26-2010, 10:18 AM | #6 |
S&P are the only ones who make a header for the 73-87 squares? Wow!
05-26-2010, 10:24 AM | #7 |
Thanks for the responses guys.
I was initially just going to get a new 350 crate to put in for the simplicity, but the power/reliability/economy for the price of getting a LS engine is starting to win me over. It's all figuring out how much work I've got to do to get there. |
05-26-2010, 10:32 AM | #8 |
Happy to be here
Take a look in our prects forums for 73-87's and 67-72's as well. There are several build threads with LOTS of info on the LSx conversions.
