Old 05-25-2010, 02:13 PM   #1
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Exhaust manifold question
Does anyone know what these fit? I assume 67-72.Are they aftermarket or GM?
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 05-25-2010, 02:16 PM   #2
Ole Greenie
Ole Greenie's Avatar
Re: Exhaust manifold question
SBC...probably a 327ci or 350ci motor.
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773
Ole Greenie is offline   Reply With Quote
Old 05-25-2010, 02:18 PM   #3
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I may have found the answer on the Dorman exhaust site. Can some one confirm this is a 69-72 NOS exhaust manifold?
Old 05-25-2010, 03:46 PM   #4
storm9c1
*** That's interesting ***
storm9c1's Avatar
I wouldn't say NOS. NOS means NEW (old stock). The part in the pic looks used. However, it looks exactly like the ram horn that's on my '69 (a short water pump 350ci). The outlet is the correct curved version. And it doesn't have an accessory bracket, both good signs that it's what you want. The 'Vette ram horns have a straight (larger) outlet. And some of the earlier ram horns have accessory brackets cast into them. Later ones had ports for the AIR injection system.
I don't have a parts lookup or a casting number book with me right now. So someone else will have to look that up for you. But by sheer looks alone, it appears to be correct.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 05-25-2010, 04:07 PM   #5
ETsC10
Hand Crafted C-10
ETsC10's Avatar
I find it odd that GM isn't stamped on it.
My '68 manifold has the assy bracket but, other than that, you will notice
dimples near the bolt holes and the GM logo stamping.
ETsC10 is offline   Reply With Quote
Old 05-25-2010, 04:09 PM   #6
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I will look at my 69 tonight. I said NOS because if you see it in person it appears to never have been on a vehicle. I also have this one which is definately aftermarket.
Old 05-25-2010, 04:17 PM   #7
jorgensensc
jorgensensc's Avatar
It might be a repop. I think the 'rams' look a little too smooth and fluid. The originals were very rough castings with casting marks pretty evident. I don't know for sure though.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-25-2010, 04:23 PM   #8
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I also got these and have no clue what they are from?
Old 05-25-2010, 04:37 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
There's one little detail in this picture that makes me sure it's aftermarket...
Old 05-25-2010, 04:41 PM   #10
jorgensensc
That's the extra one he has that he knows is repop. I did the same thing, but deleted the post when I realized he said it was a repop he also had.
Shawn
Old 05-25-2010, 04:41 PM   #11
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
lol.....
Where
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 05-25-2010, 04:41 PM   #12
67vetteal
I agree!! Al W.
67vetteal is offline   Reply With Quote
Old 05-25-2010, 04:43 PM   #13
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I know that one is Kev but what about the other with a GM part number.
Old 05-25-2010, 04:43 PM   #14
storm9c1
storm9c1's Avatar
At one point, GM switched from mounting the belt accessories to the manifolds to mounting them to the bosses in the heads. I think this change took place in the late 60's. I'll look it up in my books at home to give you the exact date. But I think the ones in the 2nd pic are from a much older SBC car (or truck?). It also appears that you have a spacer on the top manifold (2nd pic) which is for the valve that would close when the engine was cold. Often times these valves seize up and are replaced with a spacer. (Can't tell if yours is only a spacer or a hollowed-out valve)
For a 69+ truck, I would say no to the 2nd pic for sure. I know by '69 those accessory mounts were all but gone on the manifold except for MAYBE the 'Vette, and even that I'm not sure without my book.
Tom
Chevy by day...
Mopar by night...
1969 Dodge Charger
Plus others...
Old 05-25-2010, 04:44 PM   #15
Tx Firefighter
Shawn
I was just fooling around. Thankfully it's on the inboard side of the unit though. I don't believe I could stomach seeing the word "China" on the side of my engine every time I opened the hood.
Old 05-25-2010, 04:46 PM   #16
Tx Firefighter
I can't tell if it's a proper number for 69-72 trucks, but it will work great regardless of the number.
Old 05-25-2010, 04:50 PM   #17
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I bought a couple of trucks and a bunch of parts and these were included. I am probably going to sell them and did not want to misrepresent the item. What do you think is a fair price if we consider them both repops?
Old 05-25-2010, 04:54 PM   #18
Tx Firefighter
You can research them through Summit. They sell Dorman aftermarket manifolds for these old trucks. That would give you a new price so you can figure what your price would be from there.
Old 05-25-2010, 05:07 PM   #19
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
For a pair from Summitt to your door would be about $250. I was wondering what I could possibly get for them on the parts board? I know everyone here is cheap.
Old 05-25-2010, 06:07 PM   #20
sameyrasmea72
sameyrasmea72's Avatar
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 05-25-2010, 06:08 PM   #21
storm9c1
storm9c1's Avatar
I just checked my book from the first set of pics. 3932469 maps to LH 69-70 350,400ci small block, passenger car, no AIR. Dipstick indent is the little valley next to the "695" number, so this would have also been a driver's side dipstick car.
They will work correctly on a truck since trucks 67-72 need a curved dump for best fit. They should have a GM logo, so need first pics are repops. And we all know what the ones from China are all about.
Tom
Chevy by day...
Mopar by night...
1969 Dodge Charger
Plus others...
