67 4:11 gear change
would like to change my posi 4:11's to 3:08' posi in my 67 c-10 327 1/2 ton. it was suggested that 75 & 76 complete carrier will interchange as this was the only used lower gear that would work other than spending a large sum to purchase the ring and pinion and having it done, not in the budget, would anyone have any insight into how i can change the 4:11's, ty in advance.
#2 | |
Re: 67 4:11 gear change
What it really comes down to is...."You can't". There is no "cheap way" to change gears. The only feasible way is to swap the entire housing from another truck, with the gear ratio you want. This is not necessarily "easy" either, finding one is the hard part.
Installing gears is one of those things that is far more involed than it "looks". It requires precision, experience, and some special tools. It is even worse with used gears, most professionals will not even do it.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
let s see some pics
#4 | |
![]() Join Date: Jul 2008
1965 c/10 swb 1969 c/10 lwb ![]() |
hey longhair ty for replying, would u be familiar with the 75 & 76 gear change? a rear end shop in reno? mentioned that to me. my 67 has trailing arms and coil springs i have no problem removing bracketry from the old to another lower ratio rear end so having said that does anyone know what truck, std or auto, has the correct posi 3:08's thanks again this is what hot rodding is all about.
#6 | |
Which axle are you refering too? There were a few available in 1/2 ton trucks.
the gentleman that mentioned the swap said 75 &76 308's in an automatic 1/2 t. p/u truck, hope i answered your question, ty
