need help.
i have a 67 and im putting 73-87 parts and making it 5 lug disc. i bought 3 inch drop spindles and when i put them on it actually seems to sit high. they didnt do anything. why might this be? what could i have done wrong? thanks in advance.
Re: need help.
Did you keep your original springs and is the truck complete so there is weight on the front end?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Redefining LowBudget
Re: need help.
is the spring in the pocket correctly...??? also if you put a 92 2500 ( under 7300gvw) disc on it you can keep your 6 luggers
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
Re: need help.
its on jacks but i jacked up the control arm till it came off the jacks to check it. and yes it is in the pocket right. the 20's im puttin on it are a tad smaller than the tires on the rallys which makes it look like its not lowered i guess. it barely kinda edropped it 2 inches when it advertised 3(i figured it would actually be 2.5 inch) oh well.. also i got some 3 inch drop springs from cpp and they didnt do anything at all. ive checked and measured a lot and they just didnt drop it any. has anybody else had this problem? drop springs not dropping your rig? thanks guys
