Old 05-25-2010, 09:16 PM   #1
Big Blue
Big Blue's Avatar
speed cable
Hi Floks, New Help on a speed cable.
I have a 79 th350. Cluster goes to 100 mph, may not mean antything, thought i mention it. I don't have my speed od working. I checked the cluster, but did not check the gears on the trans yet. Here is the questions!
How long is the th350 cable??? The one that is in it is 43 1/2 inches long, with a white tip on it. That part goes into the cluster.
What color should the 350 gears be at the trans if I have a cluster that read 100 mph?
Thanks for the help.
John
Big Blue ( John )
79 Chevy Pick up.....My Dailey
STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in.
Big Blue is offline   Reply With Quote
Old 05-26-2010, 07:24 PM   #2
Big Blue
Big Blue's Avatar
Re: speed cable
Just bringing it to the top.
Need Help on this. Inspection comming up soon.
John
Big Blue ( John )
Old 05-26-2010, 07:39 PM   #3
mbgmike
Re: speed cable
try these guys
usually you can buy gear at dealer
http://www.transmissioncenter.net/sp...n_______va.htm
mbgmike is offline   Reply With Quote
Old 05-26-2010, 08:25 PM   #4
68Timber
I know the pieces fit
68Timber's Avatar
Re: speed cable
Is it not working at all?
If it's not working at all, unscrew it from the tranny and put a drill on the cable. Have someone check the other end. If it doesn't move the speedo needle, disconnect the cable from the cluster and have them check that end of the cable while you turn it with the drill.
I haven't had this problem in a long time, but it seems like there's two cables junctioned together on a Blazer between the tranny and speedo, that may or may not be the case on a pickup. But it's a very simple way to check.
Good luck with it.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 05-26-2010, 08:28 PM   #5
Big Blue
Big Blue's Avatar
Re: speed cable
Thanks mbgmike, I booked marked that site for future references.
John
Big Blue ( John )
Old 05-26-2010, 08:34 PM   #6
Big Blue
Big Blue's Avatar
Re: speed cable
Thanks BRUISER,
Naw,, its not working at all. It didn't work for the last two years. The last time the inspection guy said that if I don't have any miles on it he will not inspect it. Can't have that. I installed a lift in my garage and the only thing that was in it were fords. I need truck extenders to get my truck up in the air. I will do as you suggested. I may have to visit the site that mbgmike suggested.
Thanks all again, John
Big Blue ( John )
Old 05-26-2010, 08:51 PM   #7
68Timber
68Timber's Avatar
Re: speed cable
When you unscrew the cable from the tranny there will be an inch or two sticking out. Just tighten your drill tip down on the cable and spin it while someone watches the other end. You can find the point of failure pretty quick that way. It happened to me once and turned out to be a broken cable.
John
74 Honda Z50 build
Old 05-26-2010, 09:11 PM   #8
Big Blue
Big Blue's Avatar
Re: speed cable
I pulled the cable out and it is intack. That is why I think it is the gears.
I was just wondering if the right gears are in. Since I put this trans in after buying it on e-bay. The truck is a 2wd, automatic. The old speed od worked but bounced around a little. Then I put the trans in as i mentioned above.
What I thought of doing is going to my local yard and pulling everything from cluster,cable,housing and gears from trans. Thanks again,
John
Big Blue ( John )
Old 05-26-2010, 09:23 PM   #9
68Timber
68Timber's Avatar
Re: speed cable
I'd still put the drill on the cable and spin it up. That's the only way to find out if the cable is broken in the housing somewhere inbetween. It does happen.
John
74 Honda Z50 build
Old 05-26-2010, 09:27 PM   #10
Big Blue
Big Blue's Avatar
Re: speed cable
Will do, Thanks
John
Big Blue ( John )
