Old 05-25-2010, 11:01 PM   #1
S-31
Which Master Cyl To Use?
Im sure this has been asked and answered before and i've done a search and can't find a specific answer. I'm changing my 63 to disc brakes up front, but dont want power brakes, just a manual disc/drum setup. What master cylinder and proportioning valve are you guys using for that? Can a master cyl from a later model (73-87) truck with power brakes be used without the booster? Thanks
S-31 is offline   Reply With Quote
Old 05-25-2010, 11:28 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Which Master Cyl To Use?
When I swapped a 1975 suspension in my 1960 GMC a number of years ago, I didn't use a booster, just the master cylinder and combination valve from the 75. After a couple of years (and a couple of panic stops) I could no longer handle the lower back pain associated with how much pressure was needed to stop the truck, so I added a power booster. I changed the master cylinder when I added the booster, but don't remember if it was required or not.
Years earlier I had a Chevelle, and there was a difference between M/C with and without a booster. The cup in the back of one was deep, and the other was shallow. I found out the hard way by installing the wrong one, and the brakes worked like an on/off switch with no modulation at all. Easy enough to check, just look up the listings for manual or power master cylinders at any online site like Napa or Schucks, and see if it's the same part number with our without a booster.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-25-2010, 11:49 PM   #3
michaudracing
I used front discs from a '74 on my '63 Chevy. I simply used a '74 half ton manual master cylinder (the power master cylinder is different). I chucked the '74 proportioning/distribution valve and used a Wilwood adjustable proportioning valve. I still have the stock drums on the rear. I'm pleased with the master cylinder. Pedal pressure required is lower than the stock all-drum setup.
-Steve
michaudracing is offline   Reply With Quote
Old 05-25-2010, 11:51 PM   #4
raycow
In addition to the pushrod socket depth issue, sometimes the manual cylinder will have a smaller bore diameter. This will somewhat reduce the pedal effort required, at the expense of increased pedal travel.
Ray
raycow is offline   Reply With Quote
Old 05-26-2010, 08:43 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'm running an 80 model manual master cylinder on my truck. I have several power boosters under my workbench but have never felt any desire to mess with installing one. The pedal effort is very comfortable running manual setup.
Old 05-26-2010, 10:03 PM   #6
S-31
Thanks for all the help guys. Thats gonna save me a lot of time and money.
