![]() Join Date: Apr 2007
whats the best rod and main bearings for the street?
Ive been going around in circles trying to figure out what rod and main bearings I should get for my 350 build. I first turned to my engine building book called ("small block chevy performance vol 1") and it says that i should look for a strong bearing with surface behavior a secondary consideration.
It tells me that Federal Mogal AP bearings, TRW CL-77 bearings, and GM Moraine 400 bearings are the best choice for strength but they require frequent oil changes because of poor embedability. in the very next paragraph it says that for a pure drag race-race application the best bearing consideration is one with embedability and lists the best bearings ALREADY MENTIONED FOR STREET, Moraine 400 bearings, and federal Mogal AP bearings. So basically it just contradicts itself leaving the question totally unanswered. I searched all over the net only to find no real "best suited street bearing". So now i turn to u guys for advise. thanks.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht Last edited by tranz am; 05-25-2010 at 11:18 PM. |
Re: whats the best rod and main bearings for the street?
So far Ive found,
tri metal copper-lead alloy, aluminum alloy, Duroshield coated alloy, H14, Bi metal silicon aluminum, Tri metal, TM-77, Bi metal aluminum alloy Alecular silicon, Lead indium, Tri metal copper-lead nickel thats a lot of different materials to chose from??? so far Im leaning towards these. Federal Mogul Z82555CP10 - Federal Mogul CP-Series Rod Bearings and Federal Mogul Z4663M10 - Federal Mogul Main Bearing Set they both have the classic Tri metal copper-lead alloy. they are cheap so its questionable weather these can handle 400+ hp
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht Last edited by tranz am; 05-25-2010 at 11:43 PM. |
Active Member
Look at king brand bearings
http://www.kingbearings.com/ speak with the tech guys at king bearings - they seem to have the best bearings on the market currently
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
#4 | ||
"I ain't nobody, dork."
Clevite 77's have been the standard for years. I never really worried all that much about bearings. My machine shop always included them in a rebuild... and they've always been Clevites's.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
I'll look into both of those. thanks guys
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht |
I took a look Clevite 77's and it looks like they are fully grooved bearings. Im trying to stay away from those because I hear that they wear quicker and arnt quite as strong.
#7 | |||
From street/strip engines, to bone stockers... no probs. Gary
The Engine Whisperer
Put in another vote for king bearings. Thats what i'll be putting in my pretty wicked budget small block
#9 | ||
Don't get me wrong... I'm not sayin' that Clevite's are the "best" bearing out there... but for a street driven daily driver... your options for bearings are pretty easy to choose.
Gary
Chevy Lover Till The End.
X2 on the Clevite's but I buy my own and install my own after the machine work.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
![]() Join Date: Feb 2010
i use king bearing also i started using them im my honda engines that i spin to 9700 rpm and have never had a bearing failure. go to king site and read about there bearings and compare them to others and see what you think. iused to use clevite in my sbc builds till i discoverd king
x3 on the Clevite's. I've been building engines for years and always use them in my own. Sometimes people bring me a rebuild kit and say they want something else and since it's their money I put whatever they want in.
#13 |
72 Chevelle Club
I have spun my Clevite's 7500 many many times with no problem and I make over 400 hp. I also used them in my drag car for years.. My 2 cents....
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
#14 |
i say king also but honestly on a street engine any good one will do, look at the engines in my sig and profile they both have Kings in them and after 100 drag strip passes they usually look like new.
1972 super cheyenne 1970 Suburb |
#15 |
Big Red - Now its a SWB!
another vote for clevites
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
#16 | |||
![]() Gary
