Old 05-25-2010, 11:39 PM   #1
BLUE THUNDER
BLUE THUNDER's Avatar
Blazer sidelined.
I think it might be the battery! Voltage drops down to 4 under a load. Gonna take it to the shop to drop the t=case and re-seal it. Gotta replace that reduction speedo thing that goes into the tranny. Mine is leaking. Hope it's done bu the end of the week.
BLUE THUNDER is offline   Reply With Quote
Old 05-25-2010, 11:49 PM   #2
Longblock
Longblock's Avatar
Re: Blazer sidelined.
Voltage Reg?....... keeping the battery from charging ...
Longblock is offline   Reply With Quote
Old 05-26-2010, 12:14 AM   #3
BLUE THUNDER
Nope, went to a three wire alt 6 mos ago.
Old 05-26-2010, 08:19 PM   #4
cleszkie
cleszkie's Avatar
Replacing the speedo reduction unit won't solve your leak issue at the t-case. You need to replace the small seal that goes around the speedo gear shaft to stop the leak. I don't remember the part number, but maybe someone else will chime in. The leak only looks like its coming from the speedo recuction unit because the oil travels past the old seal on the speedo gear shaft and into the reduction unit, which isn't designed to hold oil.
Also, if you have an auto tranny, the seal(s) bewteen the NP205 and tranny can leak. This causes tranny fluid to continuously fill the t-case and cause more leakage out of the speedo gear shaft hole because the t-case is always over-filled to a level over the speedo shaft seal. These are the things that I learned when fixiing my leaking speedo shaft seal. Hope this helps.
cleszkie is offline   Reply With Quote
Old 05-26-2010, 09:12 PM   #5
Blizz
Blizz's Avatar
i have a part number, let me look it up.
'72 K5 CST Blazer 4x4 in perpetual progress
'96 2dr Tahoe 4x4 daily driver, Black Bear Performance tune, 285-75-16 Nitto Grapplers, Magnaflow muffler, K&N Air filter, Bilstein Shocks.........E-fan, DT Tri Y or Pacesetter LTs coming soon
Blizz is offline   Reply With Quote
Old 05-26-2010, 09:17 PM   #6
Blizz
Blizz's Avatar
nevermind, can't the page isn't there anymore. here's more info
http://67-72chevytrucks.com/vboard/s...d.php?t=205720
Old 05-26-2010, 09:23 PM   #7
AJs72K5
AJs72K5's Avatar
Ask and ye shall receive. SHAZAM! --> LINK
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 05-26-2010, 09:35 PM   #8
Blizz
Blizz's Avatar
that's it! thanks AJ
Old 05-26-2010, 11:20 PM   #9
BLUE THUNDER
Thanks Blizz and AJ. I will be buying that part tomorrow. I just got back from autozone and got a brand new battery under warranty exchange. Sweet!!!! gonna drive it tomorrow. Still nn to go to the shop and change the o ring for the selector lever on the trannny to stop the leak. Next week though.
Old 06-15-2010, 12:25 AM   #10
BLUE THUNDER
Ok, one more note on the sidelined Blazer. The week before last i noticed that the steering was getting Sloppier. I wld turn the wheel but the Blazer wld keep going straight and then turn. With a little help from my daughter I was able to see that the spring pack was moving on the axle when turning. I broke out the impact and blasted them. That problem solved. Now, need to buy the part above and stop the leaks.
Old 06-15-2010, 12:54 AM   #11
Blizz
Blizz's Avatar
OR...you could get some of this stuff....
Old 06-16-2010, 12:01 AM   #12
BLUE THUNDER
Got all the belts back on Ol' Yeller and fired it up. Runs like a champ. Think I'm gonna drive it tomorrow and have some fun. I can't wait to get the body mounts done so I can take off the top. Btw, thanks Blizz for the "putty" suggestion. Maybe next time.
