Old 04-07-2001, 06:10 PM   #1
CoryM
Question Dual fuel tanks valve
Hi, I have a 77 C20 with saddle tanks. The only tank it will pull gas from is the passenger side one. I assume that the electric valve is stuck in pass. side position. If I clean up the valve and it still doesnt work.... can I just replace it with a piece of hose so that it just goes to one tank? I just don't want to pull the valve and then not be able to drive it if I break it or something. Also how do the senders work? Does it just switch between sender units when you push the switch?
eg. if its on passenger side tank and reads empty when you switch it to the drivers side tank will it read full? Never had a dual tank setup before. Thanks a lot. CoryM
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada http://www.geocities.com/chevroletc1070/
"Take up our quarrel with the foe:
To you from failing hands we throw
The torch; be yours to hold it high."
Lieutenant Colonel John McCrae, Canadian Army
CoryM is offline   Reply With Quote
