05-26-2010, 09:25 AM | #1 |
My shaft is too short
After putting in a f&%# 9", I purchased a nice aluminum drive shaft with a spicer slip yoke and 1350 u joints from another boardmember. After measuring and having the DS cut and balanced I found out I needed to change the pinion yoke as it was not for a 1350. Now I have 2 1/4" of slip yolk in the tailshaft and 1 1/2" out (pictured) I was shooting for 1" - 3/4" of slip yoke out. Am I still good ? Need I test whats left of my sanity moving the engine/ trans back? This is how it sits on at a static drop with all for wheels on the ground. Thanks for any help.
05-26-2010, 09:35 AM | #2 |
The Older Generation
Re: My shaft is too short
Most places I have read say to push the yoke into the trans as far as it will go and pull it out 3/4 to 1 inch, then measure for your drive shaft length. Hope that is what you wanted... LockDoc
05-26-2010, 09:42 AM | #3 | |
*** That's interesting ***
Is that 1 1/2" measured with the back-end lifted? Because when the suspension is fully unloaded, that is where you have it maxed out. If that's the case, I think you can get away with 1 1/2" out, as long as it pushes in when you reload the suspension. Any more than that could be a problem. More specifically, if you plan on doing any burnouts with 1 1/2" out, you may zip the splines right off. But if you plan on driving it easy, you shouldn't have any problems. If you do want to cut corners and leave it like that, I'd get a drive shaft loop regardless. That way if it does come out, it won't be catastrophic.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... Last edited by storm9c1; 05-26-2010 at 09:44 AM. |
05-26-2010, 09:43 AM | #4 |
Well prior to having it cut, thats what I was going for. Now that it's cut and I had to change the pinion yoke this is what I have...
Storm: this is wheels on the ground, suspension loaded. No burnouts, Why else would I have a BBC Never looking to cut corners on something my family will be riding in or that could harm others. Last edited by SOON2BLAZE; 05-26-2010 at 09:49 AM. |
05-26-2010, 09:56 AM | #5 | |
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
05-26-2010, 11:18 AM | #6 |
Grandpa in the rustmobile...
I lol'd at this thread..
good luck bud
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
05-26-2010, 12:30 PM | #7 |
SWB 4x4 Collector
Glad I wasn't the only one that found humor out of the title. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
05-26-2010, 12:56 PM | #8 |
05-26-2010, 02:45 PM | #9 |
Do it right. Also, install a drive shaft loop, too, just in case your shaft lets loose. You don't want the front of your shaft to drop onto the ground, pile drive your rear end and end up pole vaulting the entire truck.
05-26-2010, 04:38 PM | #10 |
thats what she said
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
05-26-2010, 05:39 PM | #11 |
sorry i had to chime in.. when i first seen the title i about spit the pop i was drinkin out from laughing haha.. sry i just had to comment
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
05-26-2010, 05:40 PM | #12 |
check with the shop that is going to do the new drive shaft 1st!!!! I all the drive shafts that i have ever replaced they have ALWAYS told me to put the truck on the ground "normal ride height" put the yoke all the way in to the back of the trans and the measure from center to center of each U joint loops and they will take out what is needed.
05-26-2010, 06:27 PM | #13 |
20' Daredevil (Ret)
Many of us have the same problem, but few of us will admit to it publicly.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 05-26-2010 at 06:28 PM. |
05-26-2010, 07:48 PM | #14 |
Shake and Bake!
I am pretty sure they make pills for that...
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
05-26-2010, 08:18 PM | #15 |
Ya gotta get peoples attention somehow! I always appreciate the humor on the board ( which rubbers are the best, lets see your double D's ect... thanks for all the input, found a longer slip yoke on Denny drive shaft today.
05-27-2010, 02:18 AM | #16 |
i like that double d thread on here haha
05-27-2010, 09:35 AM | #17 | |
I guess there's enough people in the world with short shafts that could always use an extension on the slip end. Now you don't have to feel so concerned when your wife drives.
05-27-2010, 02:00 PM | #18 |
Its a Truck Thing......
This is just one post that really should be titled differently.....I am just saying....
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
05-27-2010, 06:48 PM | #19 |
05-27-2010, 08:11 PM | #20 |
Big Red - Now its a SWB!
Funny stuff! glad you got it figured out.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
05-27-2010, 08:51 PM | #21 |
Don't forget...it's not the length of the shaft that matters, it's how you use it that counts....
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
