Picture request 4x4 front spring mount
Hi,
I am looking for pics of the front spring front hanger for a 65 4x4 truck. On the truck would be great, also trying to see an approximate location of where they are hung in relation to the front body support. Pictures of the front spring rear mount (the one that goes through the frame) also appreciated. |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: Picture request 4x4 front spring mount
http://67-72chevytrucks.com/vboard/s...d.php?t=397681 I'll can get you the pictures you need.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
How about a straight on close up that shows full frontal so i can get placement of shackle hanger in relation to the core support mount.
Appreciate it. |
Thanks a ton, the first two pics are exactly what i was looking for. Last question. Can you tell me the distance between the front spring mount hole and the center point of the hole cut in the frame for the front spring?
Does your 64 not have an emergency cable? Measuring mine it puts the center about where the cable fot the emergency brake goes.
43 1/4" between the center of the ( front ) spring mount to the center of the (front ) rear spring mount hole.
Emergency cable was removed for painting. It goes through the slotted hole above the ( front ) shackle. The slotted hole in the second picture.
The center of the shackle mount through the frame is approximately 5 1/2" from the face of the front cab support.
Thanks a ton
I'm a little late to the party, but here are some more shots. Saw your post at work and just snapped these when I got home. Figured since I've already got 'em ready I'd share too. Sorry if they're redundant.
no its good, its the opposite side of the truck
#13 |
Here are a few that I sent to your e-mail.
#14 |
LilRed, in picture 3 what is the reddish orange color? Did they miss areas when sandblasting, or is that area blasted harder than the rest?
#15 |
The discolored area is where a small area has turned. The K20 frame is going in self-etching primer in a few days, so no more flash-out.
#16 |
One more measurement if I could please.
We decided to fab these up instead of purchasing a stock set and then having to modify for the 73 through 84 spring. So could i get the measurement from the bottom of the frame to the center of the shackle bolt? Or from the bottom of the mount flange that mounts to the bottom of the frame to the center of the shackle bolt then the thickness of the material used for the mount. Either way would be fine. I really appreciate it guys. Last edited by biohazardbill; 06-09-2010 at 07:49 AM. |
