Old 05-26-2010, 01:47 PM   #1
The--Tank
Switch or Valve?
Hey guys I'm new to the site and I have been trolling around looking for the answer to my question but can't seem to find it. I just bought my son an 86 4x4 the the PO replaced the 305 with a 350 and it runs and drives great, my only problem is when I'm running on the driver side tank around 70 it starts cutting out real bad like it is starving for fuel. I thought it might have been the carb but runs fine on the other tank so it leads me to belive it's either the switch on the dash or the valve under the truck. Thoughts?
1986 Chevy 1/2 ton 4x4 350 Auto Shortbed Fleetside
The--Tank is offline   Reply With Quote
Old 05-26-2010, 01:52 PM   #2
wheels67
wheels67's Avatar
Re: Switch or Valve?
Does each tank have a fuel filter? Replace those. Check the rubber lines back at tank for cracks starting. If so a small vacumn leak may inhibit pull of fuel at speed.
wheels67 is offline   Reply With Quote
Old 05-26-2010, 01:56 PM   #3
The--Tank
I had that thought too but the only filter I can find is in the engine bay and the one on the electric fuel pump. I forgot to say the 350 is a center bolt valve cover engine so he had to put an electric fuel pump on it.
Old 05-26-2010, 04:13 PM   #4
Gregs71
I believe there is a filter on the frame rail about under the passenger side of the cab.
1995 GMC 4x4 1/2 ton
1999 Jeep Wrangler w/ 33's
68 camaro 350/350
1987 Chevy 3/4 ton 4x4
Suzuki DRZ 400s Dual Sport
1971 chevy long bed 2x4
194? Dodge 2.5 ton
1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455
1989 Chevy V30 crewcab dually 454/TH400
Gregs71 is offline   Reply With Quote
Old 05-27-2010, 11:53 AM   #5
The--Tank
nope no filter the PO must have taken it off. It only does this on one tank the other runs like a champ!
Old 05-27-2010, 10:10 PM   #6
1LowToy
Try trading the fuel caps left to right. Dumb but worth a try for free. One may not be venting. The valve may be obstructed on one side. It can be by-passed to one tank or the other to eliminate the tank screen.
1LowToy is offline   Reply With Quote
Old 05-28-2010, 05:12 PM   #7
The--Tank
Worth a try! I just don't want to start throwing money and parts at it, the other tank works fine
Old 05-28-2010, 07:29 PM   #8
dyno
dyno's Avatar
I had the same problem for 2 years on my 80. Replaced my fuel pump, filters, gas caps and selector valve. Still screwing up...made me nuts. Finally, I found the fuel line was split and sucking air just above one tank where I could not see it until I removed it.
"Built- not bought"
1958 GMC 150 4x4 in progress
1980 K20- Restored
1985 K3500 Flatbed
58 GMC 4x4 build thread:
http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675
dyno is offline   Reply With Quote
Old 06-24-2010, 04:34 PM   #9
The--Tank
Ok this is starting to piss me off!! The right side is now starting to cut out and now the gage is all jacked on both sides. The left shows full half way around to the E and the right bounces around like it's on crack!!! Could I have a bad ground ?
Old 06-24-2010, 05:00 PM   #10
dropd80s
dropd80s's Avatar
I would say with your initial description it would be a split in the fuel line on the one side. Now that both sides are screwing up it may be possible that your wiring to the selector valve may be not let it fully switch from one side to the other. Its a relitively simple system but, if you get tired of diagnosing problems you can bypass the valve and one tank untill you get time to mess with it again.
dropd80s is offline   Reply With Quote
Old 06-24-2010, 05:10 PM   #11
Prerunner1982
Prerunner1982's Avatar
The Tank... welcome from Edmond. Where in OK are you?
With your initial problem being related to one tank I would suspect it is in the lines for that specific tank to the engine (as mentioned a split) or with the tank itself. If it only does it around 70mph this would also support the leak theory due to high pressure by the fuel pump.
As far as the gauge problem, a bad ground/connection at the senders, or perhaps a bad connection at the gauge can cause it to read incorrectly or bounce.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 06-25-2010, 02:32 PM   #12
The--Tank
Thanks for the reply. I'm down south by Blanchard but my folks still live in Edmond and that's were I went to High School. I guess I will have to pull the bed off and just check the hoses up there I don't see any cracks on the ones I can see.. I did rub a hole in the fuel line yesterday though!!! Great fun!! Nothing like watching the guage go from full to empty in 20 miles. I really need to just replumb this thing motor to tank. Any reason I should have a fuel pressure reg on this thing. It's a stock motor with a 4 barrel. I have never had one on any motors I have built before but then again this is the first electric fuel pump I've had too.
