sterring column?????
how do u identify a steering column, mine is definitley not the stock column but its been in for years. I have no idea? i had a floor shifter and ddont like it so i want to use a regular shifter, seems to hve the shifter but not sure if it will work, i also need the bushing at the lower piece by the mechanism. id buy a new one but the turn switch is new, it has no play on the top and not in bad shap help guys...
![]() Join Date: Apr 2010
Re: sterring column?????
What kind of trans do you have? Does your column have the ignition key in it? If you could show some pics it might help
i have a turbo 350 for now, tilt column no key, the firwall bracket fits, wiring plugs right up but hazards don't work.
Back in the sticks
Hazards may just be the flasher is bad. If it fits and has no key on it, it may be a van tilt. Pics would definitely help ID it.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
