what panhard should i use?
I gotta 66 c20 that i swapped a 69 1/2 ton rear onto. the panhard mount from the frame and the rear end sit at different angles, i know it's because my old rear had a bracket that stuck way out towards the back and the new rear's panhard mount is right on the pumpkin. So, what do i do now?
'66 c10ish straight 292 power! |
SSN 706
Re: what panhard should i use?
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 05-26-2010 at 09:28 PM. |
The CPP pan hard bar i used, bolts to the old location on the drivers side of the frame. The bottom bolts to a braket that go's on the trailing arm under the axel on the passenger side. The bar is ajustable to make it the size you need to center your axel. Hope this helps you out some.
This is the kit i bought: http://www.classicperform.com/Store/.../6572CDTBK.htm I think its CPPJEFF on this forum that can help you out with this.
66 short wide fleet sbw = Gave to my best friend 66 short wide fleet bbw |
