02-13-2003, 07:19 PM | #1 |
? How many are running ram horns?
69 swb stepside, rebuild and upgrade in progress |
02-13-2003, 07:24 PM | #2 |
i love summertime
me
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
02-13-2003, 07:35 PM | #3 |
me2
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
02-13-2003, 07:40 PM | #4 |
me3
Jeremy '71 C-10 '72 GMC K2500 '72 Nova (Dad's) '70 Chevelle SS '55 Sedan Delivery Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall |
02-13-2003, 07:41 PM | #5 |
I am on the 68 and headers on the 69
Mario and Mandy Hughesville, MD 20637 69 C10 305/350 71 K5 Basket case 75 K10 Rescue **Parting out** 77 MG Midget **Parting out** 15 6.7L Cummins |
02-13-2003, 08:00 PM | #6 |
newly minted old timer
me, i like em,
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
02-13-2003, 08:04 PM | #7 |
Thinking of using the horns Headder smight sound nice.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-13-2003, 08:18 PM | #8 |
14.1 @ 96MPH
I am, but namely because I can't afford to go with headers yet.
Project1970 - LS1 Swap Complete! |
02-13-2003, 08:32 PM | #9 |
Seasonal Poster
im with Project1970 on that one, cant afford anything else
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
02-13-2003, 08:41 PM | #10 |
Me a while ago
someone rear ended me and brock them both. I had a set of 1 7/8's headers so i had exhaust shop install and insurance pay much cheaper than the $400 set of ram horns manifolds.
O ya headers sound MUCH smoother |
02-13-2003, 08:43 PM | #11 |
Fabricate till you "puke"
Nadda.....full length headers for my "toy". crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
02-13-2003, 08:59 PM | #12 |
I took headers off, mainly because they didn't fit very well. The right side rubbed the frame and the brake lines, doing a big number on my brake fliuid.
They also had every bolt loose, at the header and the collector. Glad to go back to the ram horns....and if you want to get them cheap.....go to a muffler shop......they throw away alot of them for people changing over to headers. Guess they don't know what they are worth.......
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
02-13-2003, 09:06 PM | #13 |
Original equipment here too.
Saskatoon, Saskatchewan Canada |
02-13-2003, 09:18 PM | #14 |
Yep, straight dump.
'72 Suburban 4X4 "Save the Earth, kill yourself" |
02-13-2003, 09:22 PM | #15 |
i run them too.
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
02-13-2003, 09:36 PM | #16 |
I run them, they're both cracked... installing headers soon.
72 GMC Sierra Grande 00 GMC Sierra SLE 67 Pontiac LeMans/455 67 Pontiac LeMans/326 |
02-13-2003, 09:47 PM | #17 |
hey p455. are they big or small cracks? if they are not to bad ill buy them off you for a few bills
02-13-2003, 10:59 PM | #18 |
PROJECT 7DEUCE
me too
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
02-13-2003, 11:21 PM | #19 |
Jackal2k9: They're not that bad, the drivers side crack is an inch or so long and maybe .025 wide.. I haven't looked at them in a while. I'll let you know. Probably not going to put headers on until I convert to an auto trans this spring/summer, but I'll hang onto them for you if you want them.
02-13-2003, 11:22 PM | #20 |
Location: Katy, TX...but the love of my life resides in Dublin,OH.
so.....
What is a set of good, not cracked, and good studded rams horns worth? I have a set that came off my 71 because my heads wouldn't accept them... the valve covers were hitting them. I had to go with Headers. I was going to slap them on the 68 if it ever got a v8 but I have 2 sets of headers... I have the ones that sweep back, instead of going straight down.
02-13-2003, 11:22 PM | #21 |
deffinately. and if you dont want to go to headers i can have them patched for you cheap 15 bucks or less.
as long as its not craked around the gasket surfaces. Dirt Dobber: the exhaust shop wanted to charge me 200 a pop to get replacements when mine were broken in a collision. Thats inflated a bit... ebay value is 125-300 depending on numbers, condition, etc. Last edited by Jackal2k9; 02-13-2003 at 11:25 PM. |
02-13-2003, 11:24 PM | #22 |
Low & Slow
I was until a had a little incident at the lake.... I didn't realize how deep a hole was and went down into it...I didn't get stuck but it bent my exhaust pipes up into the bed floor broke my carrier bearing bracket and cracked the passenger side manifold where you could see inside of it.... sucked but it's fixed now and i have some cheapo flowtech headers on it now
70' C-10 LWB Fleetside 4.5/6 drop |
02-13-2003, 11:26 PM | #23 |
yeah rams horns are weak as hell... but if you do use them they flow very well... good to 300 hp or so.
02-13-2003, 11:29 PM | #24 |
Holy Cow
Well I guess I'll dig'em out this weekend and put them out there for sale. I know they are in very good shape. I was kinda tweaked when I could'nt use them.
02-13-2003, 11:32 PM | #25 |
how about some 63-64 vette ones worth? straight dump. thats what i have i think they were 3" or 2.5''
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
