Old 05-27-2010, 12:20 PM   #1
vtwinsport
vtwinsport's Avatar
fuel type-fanning the flames
Ever wonder what kind of fuel to run in your engine? Here is a quote from an engineer below on the subject- Fuel for the discussion fire ')
***Just so you are aware, "octane" is not "power". In fact, "premium" gas (the stuff with the higher octane number) has fewer BTUs per gallon than "regular" gas.
The extra power that is 'found' with "premium" gas is not a result of the gas. It is a result of higher compression in the cylinder, due to different pistons or cams. Increasing the compression ratio also increases the heat generated by compression. If the compression is raised enough, the mixture can get hot enough to ignite itself. This is called "pinging" or "knocking". Gas with a higher octane number will resist this heat better and will wait for the spark to ignite it. "Premium" gas also burns slower, so you have to light the fire a bit sooner by advancing the spark. How many of us have "advanced the spark" to get some more power?
"Premium" gas and spark advance are both Band-Aids to cover the heat from the increased compression. In your stock engine, neither one is necessary. In fact, just by switching to "premium" gas, you usually lose some power and mileage because there are fewer BTUs and the fire is still burning as the piston goes down, lowering the BMEP (Brake Mean Effective Pressure).***
Sounds reasonable don't it.
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262
http://beerbreadbike.wordpress.com/
vtwinsport is offline   Reply With Quote
Old 05-27-2010, 01:10 PM   #2
eightyfive
eightyfive's Avatar
Re: fuel type-fanning the flames
Woe, i never knew that, And i Work at a Gas Station! Thanks
parts truck- 1982 suburban GMC Sierra Classic
first project- 1985 GMC Sierra Classic
first truck- 1988 GMC Sierra sle
"New" Hot rod 1999 Chevy silverado 5.3L
Workin my way up the food chain
eightyfive is offline   Reply With Quote
Old 05-27-2010, 08:39 PM   #3
redneckchevy
redneckchevy's Avatar
I have stock compression in my 350 but i still run "premium" gas (91 octane) , just to get rid of the ethanol.
redneckchevy is offline   Reply With Quote
Old 05-27-2010, 09:40 PM   #4
baclay9
That is exactly right. The only reason for anything higher than 87 is if you are experiencing "pinging" or pre-detonation due to high compression. Otherwise you are wasting your money.
baclay9 is offline   Reply With Quote
Old 05-27-2010, 09:43 PM   #5
Goldfinger
Goldfinger's Avatar
I had a 10% jet fuel 90% 89 octane. 40 gallon lasted me a week. The engine was getting hotter than usual and i think i got rid of the carbon in my engine(as well as my seals).
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
