5 bolt wheels
Is there any info on which models and years are inter changable in the 5 bolt wheels.
I see a set of 72 camaro wheels and have a 68 pickup and wonder if the are the same pattern |
Gone Fishing
Re: 5 bolt wheels
GM Trucks 71-87 5 lug are 5 on 5 gm car are 5 on 4.75 bolt pattern I believe 88 and up are considered metric bolt patterns but could be wrong
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
Has more rust than truck...
Re: 5 bolt wheels
88-98 2wd rims will fit, you'll need to use your current lug nuts though.
![]() Join Date: Sep 2007
Re: 5 bolt wheels
somecars are actually 5 on 5 like the 93 impalas but the camaros are 5 on 4.75
1967custom |
Re: 5 bolt wheels
Yes---i went through this myself as i was trying to get some decent replacement tires cheap.
i think most of the B and C body cars from 70's on up had the 5X5 pattern-----impalas/caprice, bonneville, oldsmoboggie 88/98, lesabre/electra etc. i don't have time to dig it up right now---real busy (i know a cop-out), but the info is out there, or i'll post it if/when i get the chance. p.s. also some astro(van) whls are interchangable. (i think?) |
#6 | |
Re: 5 bolt wheels
I really appreciate that, and when you do get a chance I would love to see it. Quote:
Re: 5 bolt wheels
Buick all full size (electra, le sabre,riviera) 1964-87 5 x 127
5 x 5 1/2-rh 78.3 buick all full size, electra, le sabre, riviera 1964-87 5 x 127 5 x 5 15 x 7 1/2-rh 78.3 l buick roadmaster, estate wagon 1990-96 5 x 127 5 x 5 15 x 7 12 x 1.5 78.3 l buick roadmaster, estate wgn 1990-96 5 x 127 5 x 5 12 x 1.5 78.3 cadillac fleetwood 1986-96 5 x 127 5 x 5 15 x 7 12 x 1.5 78.3 l chevrolet caprice classic 1991-97 5 x 127 5 x 5 12 x 1.5 78.1 chevrolet impala ss 1994-96 5 x 127 5 x 5 12 x 1.5 78.1 chevrolet wagons & hd models 1955-95 5 x 127 5 x 5 1/2-rh 78.3 chevrolet/gmc 1/2 ton blazer, jimmy, suburban full size 2x4 1971-91 5 x 127 5 x 5 1/2-rh 78.1 chevrolet/gmc 1/2 ton blazer/ jimmy 1971-91 5 x 127 5 x 5 15 x 6(7) 1/2-rh 78.3 l chevrolet/gmc 1/2 ton truck all models 2x4 1967-87 5 x 127 5 x 5 1/2-rh 78.3 chevrolet/gmc 1/2 ton truck all models 2x4 1988-98 5 x 127 5 x 5 14 x 1.5 78.3 chevrolet/gmc 1/2 ton trucks all models 2x4 1967-87 5 x 127 5 x 5 15 x 6(7) 1/2-rh 78.3 l chevrolet/gmc 1/2 ton trucks all models 2x4 1988-98 5 x 127 5 x 5 15 x 6(7) 14 x 1.5 78.3 l chevrolet/gmc astro/safari 1985-02 5 x 127 5 x 5 1/2-rh 78.3 chevrolet/gmc astro/safari 1985-92 5 x 127 5 x 5 15 x 6 1/2-rh 78.3 l chevrolet/gmc c-1500 pickup 2wd 1988-98 5 x 127 5 x 5 14 x 1.5 78.1 chevrolet/gmc caprice classic 1990-97 5 x 127 5 x 5 15 x 7 12 x 1.5 78.3 l chevrolet/gmc impala ss 1994-97 5 x 127 5 x 5 16 x 8 12 x 1.5 78.3 l chevrolet/gmc safari 1995-02 5 x 127 5 x 5 1/2-rh 77.8 chevrolet/gmc savana 1500 2001 > 5 x 127 5 x 5 14 x 1.5 78.3 chevrolet/gmc suburban/ full size 2x4 1971-91 5 x 127 5 x 5 15 x 6(7) 1/2-rh 78.3 l chevrolet/gmc tahoe, yukon 2x4 1992-99 5 x 127 5 x 5 14 x 1.5 78.1 chevrolet/gmc tahoe/ yukon 2x4 1992-99 5 x 127 5 x 5 15 x (6)7 14 x 1.5 78.3 l chevrolet/gmc van express van 1500 1997-02 5 x 127 5 x 5 14 x 1.5 78.3 chevrolet/gmc van g-series 1/2 ton 1971-02 5 x 127 5 x 5 1/2-rh 78.3 chevrolet/gmc van g-series 1/2 ton 1971-96 5 x 127 5 x 5 15 x 6 1/2-rh 78.3 l chevrolet/gmc wagons and hd models 1955-95 5 x 127 5 x 5 15 1/2-rh 78.3 l chevrolet/gmc yukon 2wd 1992-99 5 x 127 5 x 5 14 x 1.5 78.1 chrysler pacifica 2004 > 5 x 127 5 x 5 12 x 1.5 71.5 h chrysler pacifica 2004-08 5 x 127 5 x 5 12 x 1.5 71.5 chrysler town & country van / voyager 2008 5 x 127 5 x 5 12 x 1.5 71.5 dodge caravan 2008 5 x 127 5 x 5 12 x 1.5 71.5 ford full size (custom, galaxie,t-bird) 1973-78 5 x 127 5 x 5 1/2-rh ford full size custom 1973-78 5 x 127 5 x 5 15 x 6 1/2-rh l ford galaxie, thunderbird 1973-78 5 x 127 5 x 5 15 x 6 1/2-rh l jeep commander 2wd, 4wd 2006-08 5 x 127 5 x 5 1/2-rh 71.5 jeep grand cherokee 1999 > 5 x 127 5 x 5 16 x 7 1/2-rh 71.5 h jeep grand cherokee 2wd 4wd, srt8 4wd 1999-08 5 x 127 5 x 5 1/2-rh 71.5 jeep wrangler 2007 > 5 x 127 5 x 5 17&18 1/2-rh 71.5 m/h jeep wrangler 2 & 4wd, sahara, rubicon 2007-08 5 x 127 5 x 5 1/2-rh 71.5 lincoln continental 1973-79 5 x 127 5 x 5 15 x 6 1/2-rh lincoln continental, mark iii 1973-79 5 x 127 5 x 5 1/2-rh lincoln mark iii 1973-79 5 x 127 5 x 5 15 x 6 1/2-rh mercury cougar xr-7, marauder 1973-78 5 x 127 5 x 5 15 x 6 1/2-rh mercury cougar xr7, marauder, marquis,meteor 1973-78 5 x 127 5 x 5 1/2-rh mercury marquis, meteor 1973-78 5 x 127 5 x 5 15 x 6 1/2-rh oldsmobile all full size 88, 89, rwd (w/ 403 eng.) 1964-92 5 x 127 5 x 5 15 x 6 1/2-rh oldsmobile all full size 88, 98,rwd (w/403 eng.) 1964-92 5 x 127 5 x 5 1/2-rh pontiac all full size rwd (w/ 403 eng.) 1971-90 5 x 127 5 x 5 15 x 6 1/2-rh 70.3 pontiac
big old burb in primer.lot of work to do. Last edited by scooterskoolkustoms; 05-27-2010 at 05:52 PM. |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: 5 bolt wheels
I heard the Jeep wheels have small center holes that arent friendly with the hubs on our trucks, can anyone confirm this?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Re: 5 bolt wheels
I think that's the last dimension in Scooter's list. The Jeep and Chrysler wheels have 71 mm center holes and the GM have 78 mm.
Ray Last edited by raycow; 05-30-2010 at 06:07 AM. |
Re: 5 bolt wheels
yes u r right.It is the hub bore dimension.
big old burb in primer.lot of work to do. |
