02-13-2003, 07:57 PM | #1 |
longbox conversion???
Does anyone out there know what a longbox to a shortbox conversion would entail? Has anyone done this? I am definitely thinking of doing this in the near future. Any ideas would be appreciated!!!
'68 Chev C-10 '91 Western Star (workin wheels) Just an ole time truckin idiot! Jim G. |
02-13-2003, 08:15 PM | #2 |
It has been done and there is some good information on it. I would suggest doing a search and try to find E-Fabman's post with pictures. He has a very good method for doing the shortening. Try "frame" search for the last (6) months.
Jim |
02-13-2003, 08:20 PM | #3 |
Checked the link does not work.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-13-2003, 10:41 PM | #4 |
Got big-block?
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
02-13-2003, 10:47 PM | #5 |
People I've talked to say it isn't too tough. I'd like to do the same thing to my truck if I could find a rust free shortbox. The conversion should just amount to taking some inches out of the middle and a few inches off the back of the frame and putting in new driveshafts and brake lines.
02-14-2003, 12:06 AM | #6 |
Project 7dos
i have done it
PM me with your questions... I will be glad to help you Jason
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
02-14-2003, 01:16 AM | #7 |
Jason, would you not have to cut down the trailing arms as well?
02-14-2003, 01:47 AM | #8 |
i love summertime
no, trailing arms dont change as far as i know Jim
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
02-14-2003, 03:41 PM | #9 |
Project 7dos
only thing needing shortening is Frame - 12 In. between cab mounts. 8 in. off back. Brake lines and drive shaft. I may be forgetting something but that's all i think..
even though i did it to my own truck lol thanks jason
02-14-2003, 04:05 PM | #10 |
Thanks Jason. I will get back to you if i get in trouble!!!
02-14-2003, 04:16 PM | #11 |
I thought that in the Totally Polished article on an older truck it took out a pair of bed mounts. I don't even know how many bed mounts there are in each box of these eras. D@mn I really need to get my truck to my house.
Brandon |
02-14-2003, 04:24 PM | #12 |
i did it the easy way, went and found a short bed frame, and moved everything else over.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
02-14-2003, 04:38 PM | #13 |
Project 7dos
Don't do anything to the bed mounts... they are fine. The only mounts that need to be moved are the cab mounts. Last mount 12. in. back
Jason
02-14-2003, 06:43 PM | #14 |
They do need to be removed the pair closest to the cab look at any short box frame and you will see on less pair of mounts... Later Mario
02-15-2003, 02:15 PM | #15 |
look at your lwb and notice two of the same stlye mounts you only need one
