05-27-2010, 02:58 PM | #1 |
a/c bracket for 72
Im wanting to use the stock brackets for my compresor but i have headers and the one that bolts to the old ram horn wont fit around the headers.any one out there have any ideas?
05-27-2010, 04:38 PM | #2 |
Re: a/c bracket for 72
get a smaller sanden compressor from an aftermarket upgrade kit that doesn't require the lower bracket. Otherwise forget it, my truck was missing that bracket and the compressor was not stable until I ordered a replacement.
05-27-2010, 04:38 PM | #3 |
sounds like a special prefab deal. i dont know of any aftermarket set up...
1971 K5 CST Blazer 1951 -3100 5 window short bed 4sp 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
05-27-2010, 04:42 PM | #4 |
I added some clearance to the back of my stock bracket with an angle grinder and used spacers to take up for the thickness of the manifold. (Between the header & bracket) After it's bolted on, you can't see that the bracket has been modified. So far so good, the compressor is plenty stable and I've put a couple thousand miles on it without problems.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com Last edited by HuggerCST; 05-27-2010 at 04:46 PM. |
05-27-2010, 05:10 PM | #5 |
They make lower brackets designed for use with headers. Check Summit or somewhere like that. My problem is the top bracket with tall valve covers.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel Charleston, South Carolina |
05-27-2010, 05:12 PM | #6 |
just talked to old air,and they showed me the bracket and compressor they said i could use.I like what you did hugger cst.If there is any way you could post some picks of what you did,that would be great
05-27-2010, 05:13 PM | #7 |
member #16
Check summitt and the header mfg co's for bracket.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
05-27-2010, 05:42 PM | #8 |
that doesnt look to hard to make
05-30-2010, 01:27 PM | #9 |
Here are those pics.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
05-30-2010, 03:43 PM | #10 |
thanks for the pics
