Old 05-27-2010, 04:52 PM   #1
bigeasycigars
bigeasycigars's Avatar
2 1/2" ram horn exhaust manifolds? Or something better?
I want to swap out my headers (Hooker Competition) for some 2 1/2" ram horns. (Or is there something better that won't leak?)
Anyone know the best place to order a set?
Once done anyone who wants my old headers can pick them up free of charge.
bigeasycigars is offline   Reply With Quote
Old 05-27-2010, 07:38 PM   #2
cleszkie
cleszkie's Avatar
Re: 2 1/2" ram horn exhaust manifolds? Or something better?
Bigeasy -
I switched to 2 1/2-inch ramhorns a while back after giving up on getting my headers to seal. Best mod I ever made. I can get you the Dorman part numbers for the right and left units if you want. Think they were like $90 a piece, but I could be wrong, its been a while. You could try to find an actual GM set, but that could take a while and cost you more.
cleszkie is offline   Reply With Quote
Old 05-27-2010, 08:23 PM   #3
bigeasycigars
Love the numbers if you get a chance...I'm so ready for a leakless exhaust.
Originally Posted by cleszkie View Post
Bigeasy -
Old 05-27-2010, 08:27 PM   #4
Mike C
Mike C's Avatar
I made the swap 10 years ago and consider it one of the best mods I have made. I also went to Dynomax Hemi turbo mufflers and leave the throaty sound and almost stock noise level at idle. Here is a link to one I found, I used two of these and just bandsawed the alternator mount off and ground the sharp edges.
http://www.autopartswarehouse.com/de...1&apwidWRp8aH1
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-28-2010, 11:26 AM   #5
TonyJohnson
TonyJohnson's Avatar
Dorman 674-504
Get two of these: Amazon.com: Dorman OE Solutions Exhaust Manifold... Amazon.com: Dorman OE Solutions Exhaust Manifold...
There is also another thread discussing this above this one.
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 05-28-2010, 03:53 PM   #6
bigeasycigars
That is 2 of the left hand sides correct? These do not have the heat tubes on them? And you just grind off the alt. mounts? Correct? Thanks for the link BTW.
Originally Posted by TonyJohnson View Post
Dorman 674-504
Get two of these: Amazon.com: Dorman OE Solutions Exhaust Manifold 674-504: Automotive
Old 05-28-2010, 04:34 PM   #7
RED72blazer
urban fourwheelin
RED72blazer's Avatar
Use these remflex exhaust gaskets. i use them on every car I can.
http://catalog.remflex.com/
They will seal your headers up. I've got hooker comps that I put on 8 years ago with these gaskets. I re-tightened them at 500 miles. 8 years later no leaks.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 05-28-2010, 04:41 PM   #8
TonyJohnson
Correct.
Tony Johnson
Old 05-28-2010, 06:02 PM   #9
Doug Garland
Speedway motor has them for $60 each. Part # 930-0327-Side. Specify L or R.
Doug Garland is offline   Reply With Quote
Old 05-28-2010, 06:38 PM   #10
bigeasycigars
what's the part number you used? http://catalog.remflex.com/category_s/94.htm
Old 05-28-2010, 06:43 PM   #11
RED72blazer
urban fourwheelin
on the chevy? RF2006...I think. I'd have to check my records. I've also used them for other makes too. The work really well when you have a pitted manifold surface you need to seal.
Old 05-28-2010, 06:50 PM   #12
bigeasycigars
Have not pulled them but I'm sure they are warped.
Old 05-28-2010, 09:32 PM   #13
RED72blazer
urban fourwheelin
probably, I've had some success with bending them back on other vehicles as well.
If I was going to redo everything I probably would have gone with ram horns 2nd time around. Stock appearing is more my style now.
Old 05-28-2010, 11:28 PM   #14
bigeasycigars
Agreed ...I'm going the ram horn route less worries and its a PITA to remove drivers side.
Old 05-29-2010, 04:52 PM   #15
13lazer
13lazers' blazers
13lazer's Avatar
I am also using the 2-1/2" ram horns and I love them. I also wanted to be able to remove them easy so I could work on my heads if necessary. I cut my exhaust pipes on each side just behind my motor and I installed a ball and socket exhaust connector like the ones that were on fox body mustangs and hipo thunderbirds. I don't have the problem of trying to tighten the three bolts at the bottom of the manifold in such a tight space anymore.
1970 2wd blazer
1972 1ton blazer 4x4 in progress
1966 mustang coupe (modified)
1985 c20 suburban tow rig
1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat
almost all exempt from california smog laws intentionally.
13lazer is offline   Reply With Quote
Old 05-29-2010, 05:47 PM   #16
bigeasycigars
Very nice tip...Thanks!
Old 05-29-2010, 06:17 PM   #17
jaros44sr
jaros44sr's Avatar
Got pics? don't know nothing about fords, or a link to the ball and socket joint
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-30-2010, 12:09 AM   #18
13lazer
13lazers' blazers
13lazer's Avatar
Here are a couple of pics I just took. I cut the socket off a 1990 ford t-bird with a hipo motor. The 1987-1993 mustangs also have the same type of flanges on the H-pipe.
1970 2wd blazer
Old 05-30-2010, 12:23 AM   #19
jaros44sr
jaros44sr's Avatar
Thank you for taking the time, now I understand. Seems like a much easier setup than fooling with the 3 bolts on the exhaust manifold..yes it is tight up there
Nice Bass!
SAFETY FIRST
AS usual, off topic
Jim
Old 12-04-2012, 11:46 PM   #20
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Old thread. - Great Tip.
66 C20 Service Truck:
Old 09-02-2014, 01:30 PM   #21
chewiebarker
chewiebarker's Avatar
Old thread with good info on Rams Horns.
1971 K20 Suburban
2012 LS1500 4WD Suburban
2003 Honda Accord LX V6 (don't tell anyone)
MY 'BUILD' THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=618915
chewiebarker is offline   Reply With Quote
Old 12-22-2014, 02:30 AM   #22
SierraMtns
SierraMtns's Avatar
x2...
SierraMtns is offline   Reply With Quote
Old 12-22-2014, 12:53 PM   #23
ddc456
Active Member
i have a set locally but im not sure if these part numbers are correct. I would like to put an original set back on my blazer but would these work?
3733976 (LEFT, LH) and 3747038 (RIGHT RH)
ddc456 is offline   Reply With Quote
Old 12-23-2014, 09:58 AM   #24
Mike C
Mike C's Avatar
Original manifolds were 2 1/4" outlet. The 2 1/2" flow significantly better and look the same for the most part, not sure about your part numbers.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 08-23-2015, 05:54 PM   #25
RedRoad
RedRoad's Avatar
zombie thread revival.
Bigeasy, which manifolds did you end up going with? Dorman? How do you like them after all this time?
RedRoad is offline   Reply With Quote
