Bed angle strips: Steel or Stainless?
I have to replace the bed angle strips on my 68 Stepper. I will get stainless for the strips, but I need to decide whether to use Stainless of plain steel for the angle strips. If I use steel, then they will be painted and the rest of the strips will be polished. I like the look of stainless but then there is the problem of how to mount them. I you weld them, then you have the problem of discoloration and a good chance of ruining them. If you bolt them through the bedsides, then there's the problem of the nuts and washers protruding on the outside.
I had the idea to weld in a steel angle iron with the vertical part pointing down, and then capping that with a stainless angle strip that is not mechanically fastened to the bedsides. Here is the initial mock-up. Anyone else tried this? Any problems? other than having to rabbet a step into the first board on the edge?
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
Re: Bed angle strips: Steel or Stainless?
Here is the final solution. BTW, you can't put this strip below the boards since there is no metal to weld to in the middle part.
![]() Join Date: Jan 2008
I would try to drill holes where they go, then plug weld them from the outside of the bed, then re-polish the stainless from the discoloration, after you grind the welds. If you get the heat and wirespeed right, there wont be much to grind. Just dont burn through. I have some spare stainless pieces from when I cut tubs in my stepside that I would be willing to send you for shipping cost. That way you could practice on something first to get it right.Let me know if you need them. Good luck!
Sorry, I didn't see you had finished it. Looks good
