Cultural Infidel
![]() Join Date: Jan 2007
bed removal
Is it possible for 1 person to remove a short fleetside bed by themselves? What equipment would this require?
posted via La-Z-Boy -Mark 1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold ![]() 1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 ![]() ![]() It may be that your whole purpose in life is simply to serve as a warning to others. A man is not complete until he is married -- then he is finished. |
Re: bed removal
engine hoist and imagination can lift the bed
motor exploder
Re: bed removal
I did mine by myself with my engine hoist and a couple ratchet straps. I lifted it up with the engine hoist at the back of the truck and just rolled it backwards after I picked it up high enough.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
Re: bed removal
I removed my LWB bed by myself, but I dissassembled the bed to do it. I removed the tailgate, disconnected the wiring and then used a impact gun to tighten all of the bolts holding the wheel wells in place until they broke. Once I had the wheel wells out of the way, I removed the bumper and bed mounting bolts so I could slide the bed away from the cab. Once the bed was away from the cab, I broke all the bolts holding the bedfront to the bed sides. I had to drill out the phillips bolts. I then broke all the bolts holding the bedside in place, with a couple of long bolts slipped through holes in strategic places so it wouldn't move until I was ready to pick it up and remove it from the bed floor. Once I removed the bedsides and bedfront, I flipped the floor off the side of the truck. Make sure when you lift any of the bed pieces, that you bend at the knees so you don't strain your back. They're all quite heavy.
Dave 1971 Chevy K10 1972 Chevy C10 |
Man of Mini-Talents
Re: bed removal
Go to the Florida forum and offer beers to all that show up.
Truck and auto performance nut
Re: bed removal
straps and a hoist...
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Re: bed removal
i removed my long bed by myself without a hoist....but it was late raining and i didn't really have a choice i wouldn't suggest it beer will always get you some help
Re: bed removal
I pulled and installed mine with an engine hoist, some ratchet straps, and a 4x4 cut just long enough to fit under the bedrails. I have a pic somewhere, and will post it if I can find it. I will say having a friend to help steady the bed while I pulled the truck out from under it was a help. If you have about 3 other friends that can come over, you can pick it up and move it yourself.
Big Red - Now its a SWB!
Re: bed removal
I got my bed lwb off by myself. I unbolted it from the frame then I put sawhorses at all 4 corners then lifted the front and propped it up with a chunk of 4x4, then slid a 2x12 plank across the sawhorses, then I repeated for the rear and drove out from under it. It was pretty rough, when I put it back on I got my cousin to come give me a hand.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
Junior Member
Re: bed removal
I have used my 1950's Jubilee F#rd tractor and a boom pole before, but have decided to buy an engine hoist.
Since I am an old guy and work alone a lot a engine hoist should come in handy. I have about got my small garage arranged so I can work on my trucks in it. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Re: bed removal
I removed my LWB by myself with a engine hoist and 4 x 4 under the rails, although it would be much easier if you had some help!
Tim |
![]() ![]() Join Date: Jul 2002
Re: bed removal
Cherry picker and some wood and old bed frame
#13 |
Re: bed removal
two post lift with the arms on thr cross braces
#14 |
Re: bed removal
Also had enough muscle left over to hold the camera and drink a deit coke. ha ha. Jim
#15 |
Re: bed removal
That looks a lot like what I did: ![]() ![]() I made a wood frame for transporting it and for keeping it up off the ground while doing the bodywork: ![]() ![]() ![]() ![]()
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#16 |
Re: bed removal
I made a metal fixture that fit under my short bed rails with little pads that fit up under the top flange of the bed with a ring welded @ the center for the cherry picker/ hook i , pushed it back& forth until it was balanced.It worked great still have it & used it many times by my self. Pat
#17 | |
Re: bed removal
