Old 05-27-2010, 09:59 PM   #1
Wildstreak
"something witty here"
Wildstreak's Avatar
starter problem?
when I hit the key it turns over for a split second then stops and makes a whining noise, I had tested it before I put it in and it worked well. is it broken or am I?
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 05-27-2010, 10:08 PM   #2
shrike
shrike's Avatar
Re: starter problem?
have you checked your flywheel for missing teeth?
or the clearance may be a little loose
1970 C10 Fleetside longbed
350/TH350
shrike is offline   Reply With Quote
Old 05-27-2010, 10:46 PM   #3
Wildstreak
Wildstreak's Avatar
Yea I looked at the fly wheel and its fine, its funny to say but it kinda makes a vroom noise lol. my dad said something was effed in the starter but thought Id ask here
57 chevy 4x4
68 burb 2wd:
Old 05-28-2010, 12:23 AM   #4
tim21391
tim21391's Avatar
is your wires good? maybe its arcing somewhere where you are loosing volts and it wont turn the starter fully
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 05-28-2010, 01:46 AM   #5
mclairmo
Sounds like the pinion gear is spinning but not popping out to engage the flexplate/flywheel. I would pull the starter and test it by putting battery cables on it. Make sure that the pinion gear pops out and spins fast. If not, it's bad.
mclairmo is offline   Reply With Quote
Old 05-28-2010, 06:29 AM   #6
raycow
Bad starter drive. The pinion is engaging the flywheel, but the overrun clutch in the drive is slipping.
Ray
raycow is offline   Reply With Quote
Old 05-28-2010, 08:08 AM   #7
cdowns
cdowns's Avatar
i'd spray the heck out of the nose of the starter with wd40 to make sure the shart is clean allowing full engagment
Old 05-28-2010, 01:21 PM   #8
Wildstreak
Wildstreak's Avatar
I had tested before installing with battery cables in a vise, it engaged fine. Im sure its like raycow says, now is it rebuild-able or should I just buy a new one?
57 chevy 4x4
68 burb 2wd:
Old 05-28-2010, 04:09 PM   #9
Wrenchbender Ret
I agree it's like Raycow say's. Buy a new starter drive & put in on the armature & you will have it fixed. They are available rebuilt but are not very good. It's not worth the difference.
Wrenchbender Ret is offline   Reply With Quote
