Old 05-27-2010, 10:31 PM   #1
Hubscrub
Cruzin
Hubscrub's Avatar
Driving problems
I have a 71 chevy and it got where it doesn't drive right seems like when you hit a bump or just a small dip or hill in the road you have to fight to keep it straight it wants to weave left and right like i'm driveing drunk or something i have had it aligned and new ball joints, tie rods etc. new front tires just don't know what to check next i am thinking i will carry it back to the alignment shop for them to check it over again. anything else i should consider? i had it tore all the way down to the frame and put a 67 frame under it and used my 71 suspension, to make it a short wheel base truck and put a 350 in place of the six thanks
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 05-27-2010, 10:50 PM   #2
joes50pu
Re: Driving problems
Check the idler arm for excessive play. You could have a worn steering box.
joes50pu is offline   Reply With Quote
Old 05-27-2010, 11:12 PM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
If it's a coil spring rear check the panhard/track bad, they probably didn't think to check the rear out.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 05-28-2010, 01:51 AM   #4
mclairmo
Also, make sure the pitman arm is good, it is a very high wear item. My truck did the same thing and it was a loose pitman arm. A loose steering box or idler arm can also cause the same symptoms. Also, get under the truck with the wheels off the ground and start yanking on the steering linkage and suspension parts and see if anything is loose. Also, check for loose front wheel bearings. Sometimes, the wheel bearings are not set correctly, causing wandering.
mclairmo is offline   Reply With Quote
Old 05-28-2010, 05:46 AM   #5
cdowns
cdowns's Avatar
do you have a swaybar?
Old 05-28-2010, 12:47 PM   #6
Hubscrub
Cruzin
Hubscrub's Avatar
no, but that is one of my next upgrades
Proverbs 3:5,6
Old 07-09-2010, 11:36 PM   #7
Hubscrub
Cruzin
Hubscrub's Avatar
update.... my dumb self installed the center link backwards and i put it in right tonight and i drove it and steered,drove great have to get it aligned again but i learned something thanks to all on the this board for helping me fix my problems
Proverbs 3:5,6
