Old 05-28-2010, 01:28 AM   #1
basemodel67
Factory Strippers Rule!
basemodel67's Avatar
68 Experts Needed!
A real brain buster here: On the trucks with an electric choke, was the manual choke hole on the firewall plugged with something or was it not drilled? My 67 will not be using the manual choke, so I want to know what the factory did. Obscure question, but I know someone here knows.
"Feast your eyes on a feast of smoke."
67 Chevy Short Fleet
PLAN: LQ9, 4L60, D60
Looking for School Bus Gauges - Help me out!
basemodel67 is offline   Reply With Quote
Old 05-28-2010, 02:23 AM   #2
breeh
Recovering 67-72 Addict
breeh's Avatar
Re: 68 Experts Needed!
Yes, there was a plug/cover. They come up for sale here from time to time.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 05-28-2010, 06:18 AM   #3
burb71
Active Member
Its a GM plug
burb71 is offline   Reply With Quote
Old 05-28-2010, 12:55 PM   #4
basemodel67
I have a handful of the bezel emblems, but what did they do to the firewall where the choke cable went through? Was there a rubber plug or did they just not drill the hole?
Old 05-28-2010, 01:06 PM   #5
vectorit
What?
vectorit's Avatar
On mine it was perforated in a circle, so you could punch it out.
I remember helping my Dad punch it out when I was young, he put a cig lighter outlet there and stuck in a map light.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 05-28-2010, 09:25 PM   #6
71 super
71 super's Avatar
The choke on the early trucks were not electric, but a heated spring type- divorced choke. The electric choke did not start until later. Engine type dictated the divorced choke or the manual choke I believe- 327 would have been divorced,307 w/ 2 bbl would be a manual choke.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 05-28-2010, 09:45 PM   #7
basemodel67
Right... but what was done with the choke hole in the firewall? Doesn't the manual choke come through right above where the windshield-washer lines go through the firewall? I would ASSume that they just used a big plug, but I just want to know what was original...
Old 05-28-2010, 10:23 PM   #8
msgross
msgross's Avatar
Mine had the oil line going through that area... It was an original divorced choke 327 until I put the new intake on...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 05-29-2010, 01:11 AM   #9
basemodel67
Thanks Mike! As long as I know that the hole was there through the firewall either way, I'm good.
Old 05-29-2010, 10:13 AM   #10
msgross
msgross's Avatar
I would think that all cabs are the same, except for A/C and non-A/C... THye use to block off uneeded holes with plates (clutch delete, radio delete etc..) The tach wire might have had a specific hole though, hard to tell..
The Garage:
Old 05-29-2010, 12:33 PM   #11
Willys47
Willys47's Avatar
I had a six in mineand the choke cable came out on the left hand side of the master cylinder above the speedo cable
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
