Redefining LowBudget
Ok summer is here I'm getting ready for the caddy swap and had a thought on keeping cool air to the carb and engine bay..so heres goes any input or thoughts are more than welcome....as you know it will be different......
If you look where your emblem is on the hood theres nothing behind it?? I was thinking of cutting a section out there (maybe the shape of the bow tie) and boxing it so that it went back over the air cleaner (you know the open kind you see) with a cut out so when the hood was closed it would fit over the air cleaner.( like the Chevelles had) ..to get fancy you could put a flap in it operated by one of the Vacum motors off one of the vents and hook it to the carb for that true ram air.....or just let it breath I figured that this would keep the hood top looking stock and since its on the flat front it would get the best ram air effect Food for thought since my hood needs work there anyway... this would be very Kool if I had the 67 style hood and the flap opened upward then layed back flat..you could even leave your bow tie on!!! Last edited by Hottrucks; 05-28-2010 at 10:12 AM. |
Re: Ram air hood ..thoughts/ideas ????
How about the hood latch?I think it`s a cool idea but I`d just run ducts under the bumper or in the wheel well.How about over or through the core support and pull air from behind the grille?
sounds like it would be pretty slick is the air cleaner going to be boxed? only thing i would wonder is if the bow-tie hole would be big enough but lots of people do just run a tube to the grille for a cold air
ramairbox.com
'72 cheyenne super step, '05 long bed gmc |
I was looking again and it seems like the hole from is almost pre boxed?? the front support only has a couple of holes so running something to duct it over the air cleaner.Yes I was thinking of boxing the air cleaner with about 1" extra to allow the rext of the cool air to blow over the intake?? Yea you could make it seal but that would be tons more work..I think?? Also since the hole front is pre boxed by the hood support you could cut the intake holes just about anywhere or any size...
my tought was to weld up the box to the hood (this helps with hood flop) also when you open the hood it has a VERY KOOL factor to it..with out duct work running everywhere and Yea I could duct air from the grill or wheel well or even the vents under the windsheild but I was just kinda thinking out loud for something new....you watch someone will take this idea and run with it$$$..it always happens to me I think this will require some cardboard, some tape and a few beers to see how it looks and fits...I only have my little ponie motor so I wouldn't make anyting out of steel till after I find out where the caddy's carb it going to sit.... beside with the motor out I could get in the engine bay and see how the clearances are..... Hmmmmmmmmmmmm............................... |
Factory Strippers Rule!
![]() Join Date: Mar 2009
What about getting one of the air inlets from a BB C-50... the kind that go through the side? I think they are kinda cool, and would look like it came that way.
![]() I don't think the hood emblem would be big enough to feed your engine... unless you get one of the giant ones off a Step-Van! ![]()
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
ok since I'm doing other things that give me a few to stare at it ...How about this
I posted pics to help Looking at the front hood support you'll notice that where my finger is pointing is in front of the rad...If I was to cut some holes into it that (I was thinking 2" hole saw 2 or 3 times) would allow cool air being pushed by the rad to go up into the hood support..... the second pic is what it looks like from the air cleaners view...you'll notice the hood body line at the top and the rad, the fan shroud (don't look at the duct tape holding the crack in it) and the large flat area above that is the hood support......a box joining the hood support and air cleaner would route the cold air to the carb... this Idea requires NO visible hood mods all that needs to be done is the under hood plumbing.... I think the camaros and vettes ae using the air before the rad Hmmmm........ hell this may even help with areo dynamics by releasing some of the air these bull dozers push...LMAO |
I want to know 2 things:
How did you get under the hood with the motor to take that second pic?? More importantly, how did you reach the hood latch to get out? ![]() ![]() |
#9 | |
knuckle buster..
![]() Join Date: Oct 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() but seriously..... how did you get those friggin shots..lol
_______________________________________________________________________________ Eric THIS SITE ROCKS!!! ![]() Check out my suburban on 20's with fresh paint! Click here to support the site Check out the Member Photo Gallery here StreetCruizin FAQ thread Site vendors list (scroll down to vendors in red) ![]() ![]() |
Camera timer. Set it, put it on the air cleaner. Close hood. Easy as that?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
SWB 4x4 Collector
![]() Join Date: Jun 2001
You can get a ram air hood at US Body that would look great. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#12 | |
knuckle buster..
#13 |
Grandpa in the rustmobile...
lol i was wondering same thing
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#14 |
Old School
You have come across the same idea that I have been pondering for quite a while. My version differs a bit in that I want to cut a couple of 3" tall by 10 to 12" long sections out of the front of the 69 hood (extra hood) on each side of the bowtie emblem. Put the cutout sections on pivots and hook the flaps up to vacuum to work as the flap on a cowl induction hood does. Then box in and seal the area directly behind it and duct the incoming air to the air cleaner. The leading edge of the hood is the highest air pressure and flow area on the truck and would be an excellent area to supply fresh air to the engine. A person could run ducting hose or fabricate an upper and lower housing as used in a standard cowl induction hood, which is what I am going to do. Just as soon as I finish all these other little modifications and projects that keep popping up.
#1 Project...69 Chevy swb Fleetside (Dad's truck) #2...1983 El Camino SS (Choo Choo Custom) #3...1974 Datsun truck (4.3L V6/4L60E) #4...1951 Cadillac Limo (1975 Caddy running gear) #5...1938 Dodge M38 3/4 ton Military truck #6...1968 Sportster XLCH trail bike 5 GMC & Chevy parts trucks 68 to 72 Last but not least; My 1978 Harley Davidson Electraglide (trusted & reliable companion for the last 30 years) |
#15 |
When doing this duct work under the hood, how do you stop the rain water from getting to the carb.?
1972 Chevy C10 SWB 1999 GMC Sonoma Mini 2008 Yamaha R1 2007 Harley Nightster |
#16 |
you have to remember that these trucks are not sealed as tight under the hood as modern day small cars with such small engines, and that is why you see so many Cold Air Intake (CAI) systems used on them. lots more room for air to circulate in our trucks.
i think it sounds like a ton of work for such a very minuscule performance gain on such a large engine. Last edited by Shane; 05-31-2010 at 11:19 AM. |
#17 | ||
Remeber that midget stripper??? Quote:
#18 | |
#19 |
funny you say that I was Just looking at this
http://cgi.ebay.com/ebaymotors/ws/eB...15429109178711 but I still like the Idea of using the high presure in front of the rad...just someting different
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#20 |
6>8 Plugless........
![]() Join Date: Sep 2007
I've used kits from Hypermax engineering on 84 up ford diesels with turbo kits, and the cowl/firewall vents work well. I had a friend's truck that had a bad windshield seal bond and every time you would lay on the throttle, the suction from the engine would pull the windshield out enough for it to leak air.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 06-02-2010 at 03:14 PM. |
#21 |
I see so many cowl induction hoods on these trucks, yet I have yet to see on where the aircleaner has the proper ducting to take advantage of the higher pressure air that can come in through the cowl. The reason the cowl induction hoods were first made was to take advantage of the naturally high pressure point crated by the windshield compressing the air as it goes by. Because of this, the air at this point is more pressurized than the air in front of the leading edge of the hood.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
#22 | |
#23 | |
#24 |
something like this...I wasn't going to goto the extreme of building the boot section...but more like the hood section
http://media.photobucket.com/image/c...O/100_1254.jpg
#25 |
Put a 72 front bumper on it and run some ducts from the turn signal holes.
