Old 05-28-2010, 12:03 PM   #1
Kim57
Kim57's Avatar
2005 Proportioning Valve?
Hi guys
I hang in the 47 to 59 secton because I'm building a 57 pro street truck.
I have a hydroboost/master cylinder off of a 2005 chevy truck and am confused on the proportioning valve.
There wasn't one on the donor truck and I have no idea if its built into the master or if they did something else.
My local dealership showed no listing for one.
I have a combo distribution/prop. valve that I think will work if I need to use one.
Hope someone in this section can help me out with this.
Thanks.
Kim
Kim57 is offline   Reply With Quote
Old 05-29-2010, 06:50 PM   #2
clinebarger
Re: 2005 Proportioning Valve?
On a 05 the Rear Proportioning is cotrolled by the ABS modulator.
The 05 master will put out a large volume of fliud. What master cylinder you use needs to be based on what braking system you have (4 wheel disc, disc/drum, 4 wheel drum). On a custom app. I whould use a adjustable proportioning valve for the rear. Several companies make them like Wilwood, SSBC, Bear, etc..
clinebarger is offline   Reply With Quote
Old 05-29-2010, 07:39 PM   #3
Kim57
Kim57's Avatar
Thanks for the response.
I kinda figured that is what they did as all the lines from the master went into a computerized box and then came back out.
I'm running 4 wheel discs and made sure the truck I got the unit off had them also.
thanks again.
Kim
Old 05-29-2010, 09:04 PM   #4
clinebarger
thanks again.
Kim
Running a hydroboost & a high volume master can make your brakes over sensitive without the correct pedal geometry. Are you mounting it on the firewall or under the floor like it was?
Old 05-30-2010, 12:47 AM   #5
Kim57
Kim57's Avatar
It's being set up under the cab. Here's a link to a page in my build thread with pics of what I'm doing. I checked out wilwoods prop valve and will probably go with it as that's what my rear brakes are. If I need to change the master I will do that also.
http://67-72chevytrucks.com/vboard/s...=283107&page=8
Kim
Old 06-01-2010, 11:17 PM   #6
clinebarger
Kim
Very nice! I agree with the other posters on the rod needing to be chromemoly. You will also need 2 pound residual valves installed in the main feed lines front & rear.......When the master cylinder is at the same level or lower than the calipers the pistons can retract from the pads & return fluid to the master, If that happens the pedal will go to the floor on the first hit after sitting or after a long drive on the highway. Very dangerous.
Old 06-14-2010, 11:43 AM   #7
Kim57
Kim57's Avatar
Thanks.
I've already got the residual valves and I'am planning on the chromemolly.
Kim
Old 12-19-2012, 03:17 AM   #8
mcmlxix
Collector of Projects
mcmlxix's Avatar
Bringing back an old thread. I have the MC and hydroboost off a '05 Silverado 2500hd. I need to know which port on the factory 05 master is for the front and which is for the rear....
Rich
1972 K5 Blazer CST Click HERE
Old 12-19-2012, 09:16 PM   #9
clinebarger
Old 12-20-2012, 01:15 AM   #10
mcmlxix
mcmlxix's Avatar
Thanks... I had a feeling they were "reversed" ....
Rich
