Old 05-28-2010, 01:05 PM   #1
ljackson
ljackson's Avatar
A/C problem
Hi, I have a 99 Yukon with a 5.7. The A/C is not working. The clutch will engage and turn the compressor if I run a jumper wire to the front plug. It does get cool. I read about a sensor that may not let the clutch engage due to low freon, hi or low pressure. I am not sure where the sensor is. While I had it jumped, I added a small amount of freon. The gauge was pegged when I first started. Now it is reading about 50 psi. When I reconnected the plug, the clutch does not engage. I did not find anything after searching with my exact problem. Is there a sensor that may have gone bad? Where is it? Can I replace it?
Thanks for your help
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 05-28-2010, 05:19 PM   #2
truckdude239
truckdude239's Avatar
Re: A/C problem
wooooo 50 psi on the low side is way too high should be around 35 psi on low side and 225-275 on high side at around 90 out side. the sensor is normally on the reviver drier
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 05-29-2010, 08:37 AM   #3
ljackson
ljackson's Avatar
Re: A/C problem
Thanks for the reply.
I took it to Firestone yesterday afternoon. They told me the compressor is going out. By the way, it was working again when I drove it home and still this AM on the way to work. They want $900.00 to fix it. Can't do that. If the compressor is the case, I will replace it myself. I can get a new comp and clutch with 1 yr warranty for $220.00. I plan to replace the compressor and drier. Should I replace the sensor on the drier? It was listed on Firestone's estimate.
Old 05-29-2010, 09:44 AM   #4
truckdude239
Re: A/C problem
compressor , drier and office tube, for warranty
David fuller
2000 Tahoe 5.3l 378
Old 06-02-2010, 09:27 AM   #5
PT'S 70 CST
"GO DAWGS"
PT'S 70 CST's Avatar
Re: A/C problem
Do not go the cheap route. I made the mistake of putting on an Advance auto compressor and replaced it twice. After the second time I wound up putting an AC Delco one on and have not looked back in two years.
PT
70 CST SWB
70 NOVA
93 Indy 500 Pace Truck (SOLD)
94 SILVERADO SWB 5/7 drop
2000 Silverado swb
2005 Nissan Altima 3.5 (Surprisingly very fast)
2004 GMC Yukon XL Denali
BATESBURG, SC. 29006
29006
Some of my restorations
http://www.snapfish.com/snapfish/thu...NAME=snapfish/
Restored Tach tins 8 cyl - 6 cyl
http://67-72chevytrucks.com/vboard/s...d.php?t=518185
Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM
God Bless Our Troops
PT'S 70 CST is offline   Reply With Quote
Old 06-02-2010, 11:39 AM   #6
Ghastlyone
Ghastlyone's Avatar
Re: A/C problem
I learned my lesson years ago about replacement parts.
It's either AC Delco or nothing.
The only thing I buy from Autozone is oil, and air freshners.
Ghastlyone is offline   Reply With Quote
Old 06-02-2010, 11:22 PM   #7
clinebarger
Re: A/C problem
When you say front plug you mean the compressor clutch coil plug on the compressor? When you jumped battery power to the clutch it got cool but not cold? You added freon then it got warm? To much freon can cause high low side readings. Never just add freon, It takes a certain amount (2.0 pounds if you dont have rear air) Putting liquid freon (cheap can tap charging tool) directly in the compressor is also a very bad idea. Try unpluging the low pressure switch and jumping it directly, see what happens. As truckdude said its on the receiver dryer
[/QUOTE]I took it to Firestone yesterday afternoon. They told me the compressor is going out. By the way, it was working again when I drove it home and still this AM on the way to work. They want $900.00 to fix it. Can't do that. If the compressor is the case, I will replace it myself. I can get a new comp and clutch with 1 yr warranty for $220.00. I plan to replace the compressor and drier. Should I replace the sensor on the drier? It was listed on Firestone's estimate.[/QUOTE]
Firestone can hardly fix a flat. Dont let inexperienced techs/greedy managers sell you somthing you dont need. Get the compressor enable curcuit working first (control head, low pressure switch, bad ground, A/C clutch relay, broken wire, etc). Charge it with the right amount of freon. What was the exact reason they gave for the compressor being bad or "going out"
clinebarger is offline   Reply With Quote
Old 06-03-2010, 12:15 AM   #8
bwood
bwood's Avatar
Re: A/C problem
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
