Old 05-28-2010, 01:34 PM   #1
fred1968
Question 1968 chevrolet c20 4 speed trans
I have a 1968 chevrolet c-20 292 6 cyl with the 4 speed manual trans and eaton rear axle. What type of trans is this? I am having an issue with not being able to shift from 2nd across to 3rd, is there an adjustment somewhere?
fred1968 is offline   Reply With Quote
Old 05-28-2010, 01:49 PM   #2
jbclassix
Junk Yartist
jbclassix's Avatar
Re: 1968 chevrolet c20 4 speed trans
SM420- Reverse is left and down
Has One PTO cover
SM465- Reverse is right and down
Has Two PTO covers
No adjustment, but they are both hard to shift if you are not used to them.
jbclassix is offline   Reply With Quote
Old 05-28-2010, 09:39 PM   #3
factorystock
factorystock's Avatar
If it is a 68, it should have a Chevy 465 or a New Process 435. The Chevy 420 was last used in 1967. The Chevy has a cast iron top while the New Process has an aluminum top.However, its possible there was a swap at some time and it may be a Chevy 420, if the 420 and 465 are interchangeable. No adjustments that I know of on all of the above.
factorystock is offline   Reply With Quote
Old 05-28-2010, 10:18 PM   #4
292farmer
292farmer's Avatar
have u checked fluid level? i got the sm465, it shifted better after i topped fluid off was a qt low.
292farmer is offline   Reply With Quote
