05-28-2010, 02:42 PM | #1 |
Water pump replacement on 02 Tahoe
have 2002 Tahoe 5.3 engine. Need to replace water pump.
Where is the peep hole on water pump, anybody have detailed instructions on replacing the water pump.
Chief mechanic for my, 54 Belair, 64 Corvair, 72 C/10Fleetside and 2002Tahoe. John 14:6 Jesus said, "I am the way, the truth, and the life. No one comes to the Father except through Me. My Book "Why Cancer is Not Bad Luck" by WestBow press |
05-28-2010, 05:09 PM | #2 |
Re: Water pump replacement on 02 Tahoe
how many gal does this system take I got it changed
05-28-2010, 05:17 PM | #3 |
2-3 gallons
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
05-31-2010, 10:06 PM | #4 |
6 pack and an hour of your time. THats all teh directions you need. Hardest part is getting the fan clutch off the water pump. There just as easy as a 5.7 water pump. I would suggest replacing both belts while you are at it. I have seen alot of a/c belts cracked.
70 C10 SWB stepside forsale 00 Silverado Z71 Sold 95 Eagle Talon TSI turbo (Hellz ya its fast) 70 Chevelle 69 firebird 10 Silverado 4x4 |
05-31-2010, 11:31 PM | #5 |
Windy Corner of a Dirty Street
Chances are you do not need a water pump but just the water pump gaskets. I see a lot of people spend hundreds of dollars on water pumps when they only needed $12 worth the gaskets.
They are the two metal gaskets on the right. GM Part number 12588372 and are less than $6 a piece.
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
05-31-2010, 11:35 PM | #6 |
Here is a link to a post I was saving:
http://67-72chevytrucks.com/vboard/s...d.php?t=343606 Its for a 04 6.0L but it should be pretty close.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec -Gibson Stainless Cat Back Swept Side -SS Wheels 2005 Honda CRF250R 2006 Honda CRF150F |
06-01-2010, 02:37 PM | #7 |
12-20-2010, 06:52 PM | #8 |
I am revisiting this post because I replaced the water pump on my 2002 Tahoe on 5/29/2010 at 162000 miles and today I have 170000 a total of 8,000 miles only 5 months and it is leaking.
The water is coming from behind the power steering pump and dripping. I could not locate the peep hole to see if it leaking through it. That is the way you check I believe. Can the pump go out that fast?? Would there be anything else to look at or for?? I replaced the gaskets when I did it would they be bad already??
12-20-2010, 11:44 PM | #9 |
umm what brand pump did you install, was it a new or rebuilt, auto aprts store special or gm pump. did you install the gaskets dry or with rtv? and to anser yes the pump can but it it is a higher end pump then i'd say they pump shouldn't be bad and it is a set of gaskets.
depending on the warranty of the pump i'll take it off and take it back and get a new set of gaskets with . the weep hole should eb behind the pullie
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 12-20-2010 at 11:46 PM. |
12-26-2010, 02:48 PM | #10 |
any luck on findout what was leaking?
12-28-2010, 09:46 AM | #11 |
have not had time but will work on it this weekend.
12-31-2010, 04:16 PM | #12 |
left side gasket was leaking at bottom running down block and on to the floor.
Bought new gaskets and it is good so far, time will tell!
