Old 05-28-2010, 03:17 PM   #1
JoeKan
JoeKan's Avatar
door is locked, won't unlock
What's the solution to getting a door unlocked? I've pulled up/down on the door handle and still won't unlock.
Any ideas?
Thanks,
Joe
JoeKan is offline   Reply With Quote
Old 05-28-2010, 03:30 PM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: door is locked, won't unlock
remove the door handle and window crank, remove door panel, and see if the rod is attached that operates the lock. if all parts are there , spray some wd-40 or liquid wrench in there, as it could be seized up.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-28-2010, 05:28 PM   #3
cdowns
cdowns's Avatar
try the key
Old 05-28-2010, 05:44 PM   #4
DZL1
One day.....
DZL1's Avatar
Why would he try the key when he can just press the onstar button!
Seriously, the door might not be aligned right so try pushing the door closed more, don't know if that makes sense. And while your pushing, try unlocking. Hope that helps.
DZL1.
DZL1 is offline   Reply With Quote
Old 05-28-2010, 07:38 PM   #5
junkyardjohn
junkyardjohn's Avatar
These old trucks don't unlock the doors with the inside door handle. You either have to pull up on the little knob, or use a key. john
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 05-28-2010, 08:54 PM   #6
dan42
dan42's Avatar
DZL1.
X2. I have problems locking my door at times - if you push in on it, it relieves the pressure on the mechanism.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 05-28-2010, 09:47 PM   #7
JoeKan
JoeKan's Avatar
Thank you all for the help. WD-40 is my friend
