Old 05-28-2010, 06:14 PM   #1
minime's 68'
68' to 70' axle swap! Need Help
I have a 68' 4x4 1/2 ton with a 4" lift and I'm going swap my axles with 3/4 ton axles from a 70' with a 4" lift. The 70's axles have 35's with a 16.5 rim. The question I need help answering is can I use the tires without any mods to fender or fender wells? Any help would be appreciated thanks!!!
minime's 68' is offline   Reply With Quote
Old 05-28-2010, 11:37 PM   #2
gus
Re: 68' to 70' axle swap! Need Help
you have the answer, cause' you have the swaping parts, tires and the truck, just take your measuring tape out do some math work and you should get question answered
gus is offline   Reply With Quote
Old 06-05-2010, 02:18 AM   #3
chevyblazer
chevyblazer's Avatar
yeah i dont think you need to cut
cucharitas customs
chevyblazer is offline   Reply With Quote
Old 06-05-2010, 08:54 AM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
How wide are the 35"s? It really depends on the specific lift and the width of the tires. I originally put a 4" lift on my 69 and the 35x12.50"s on an 8" rim didn't rub. I put those same tires and rims on my 70 K5 with a different brand 4" lift and the tires did rub a little when turning. Only way to really know is get it all installed and find out.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
