Cheap disc conversion
whats the cheapest way to go to fron disc brakes if you have 6 lugs. I know theres a site out there that sells the kits for 6 or 700 dollars, but there hs to be a cheaper option. any ideas?
PROJECT 7DEUCE
![]() Join Date: Dec 2002
How about finding a newer donar truck for the front cross member??
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
that would probably be more expensive wouldnt it? first you have to cur it off one then weld it onto another. does anyone know of spindles taht bolt directly onto the 70 fron 6 lug suspension? or that bolt on with little trouble?
did they make ne 72's with discs? are the a-arms the same? |
![]() Join Date: Oct 2002
Check GMCPauls web site. I think his kits are $450 with 2.5 drop spindles.
Thats what I plan on using, unless I can figure out how to get 13 inch rotors for not much.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds. 1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s 1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig "I like long walks, especially when they are taken by people who annoy me. " |
will do thanxs yak
We Sell Truck Parts
Do you want to stay with 6 lug or do you want to go to 5 lug. We have a complete '72 5 lug disc brake crossmember ready to bolt up for $150.
Thanks, Bo
'67 Chevy SWB 454/400 '97 Chevy Tahoe 4x4 '62 MG Midget |
PROJECT 7DEUCE
I was just talking about a newer crossmember from a newer truck they bolt on so no cutting and welding just an idea .....Yes 72 s came with disk in the front.....
