3.08 to 3.73?
Need help. Thinking of having my gears changed from 3.08s to 3.73s. Trying to decide if its worth it and if 3.73 is right. Currently running a Crate 350 with a 350TH, a 4bl carb, and 33x12.5 ATs. Its pretty sluggish know and my gas mileage sucks (about 10mpg). Will 3.73 gearing be real noticeable change and how would it effect my mileage? May eventually go to 35 but not for awhile. The 33s are only a year old. Any advise?
Re: 3.08 to 3.73?
if you planning on running 35's as your next set of tires.. go with 4.11 gears. i run 35's with a 700r4 tranny and im running 4.56. great choice imo
Re: 3.08 to 3.73?
What kinda mileage are you getting? Also, did you put the 700R4 in yourself, how hard was it? I've been thinking about swaping out my 350TH.
Re: 3.08 to 3.73?
me and a friend did it.. it was pretty straight forward.. the 700 is 2.5 inchs longer so just move the transfer case mount back had to get a 700 to a 205 adapter. do the driveshafts. works great.
#5 | |
Re: 3.08 to 3.73?
Re: 3.08 to 3.73?
Thats helpful. How bad do you think hwy driving would be with 4.11 with out OD? (70-75mph). Do you know what type of mileage you are getting with the 4.56 and 700R4?
Re: 3.08 to 3.73?
depends on how soon you are getting the 35 in tires lol. if you do more hwy driving then city or off road, then you should stay with 373's. but if you want more get up and go, do 4.11's. im building my truck for a fun toy and i dont really care about gas mileage. thats why i put a 383 stroker with 465hp/492 tq and i run 35's. if i wanted mileage i would drive a car lol. i put a 700 in it for the overdrive, knowing that it will help out on the gas bill over time. maybe someone else could point you in the right direaction.. but i would go with 4.11 if your planing on up grading your tires to 35's, even if your staying with 33's , just for the fun factor.
Re: 3.08 to 3.73?
I appreciate the help.
Re: 3.08 to 3.73?
I went with 3.42 and 33 inch tires, still gives a good hwy speed.
] ![]() 02' f350.7.3 00' F250-powerstroke 00' Roadstar 84' Eagle model 10 72' GMC 18' camery 12' ZX14R- |
Future TOTM Winner
Re: 3.08 to 3.73?
Before I tore mine down I had a 350/th350 with 3.73s and 35 inch tires and I can say it was too high geared even for highway driving. I had plans to swap it to 4.10s. On the other hand, 33 inch tires with 3.73s would be a decent choice with 3.73 gears for the highway. An overdrive would be a good choice with 4.10s or 4.56s but either way don't plan on getting "good" mileage out of one of these vehicles. They are built like a brick which isn't good as far as wind resistance is concerned. You might change over to efi, overdrive transmission, etc only to pick up a couple extra mpg, but it isn't worth the cost to get there. Now if you want updated drivetrain components simply for the cool factor/reliability, then get after it, that's what I'm trying to accomplish.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 06-11-2010 at 04:40 PM. |
Re: 3.08 to 3.73?
I have the 350/350 combo and 3.73's and 33's. I run about 2350 rpm at 55. Closer to 3k at 65 plus. Average 12.5 mpg. I should note that I rarely run over 65mph in the blazer. It really likes to go 60-65 mph. Snappy enough for me off the line.
Actually this setup and gearing with the 700R4 would be perfect in my mind. The OD should drop you closer to 2K when cruising. |
#12 | |
Future TOTM Winner
Re: 3.08 to 3.73?
I look here for calculations.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
#13 |
Future TOTM Winner
Re: 3.08 to 3.73?
Also keep in mind a lot of this is contingent on your ACTUAL tire hight, more importantly the effective radius from the center of your hub to the ground. NOT the size that is stamped on the sidewall.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 06-12-2010 at 12:37 PM. |
#14 |
Re: 3.08 to 3.73?
The big issue with trying to calculate theoretical is the torque converter slippage. My 69 Camaro with 4.10 and manual trans runs 3100 rpm at about 65 while my brothers car with T350 and 3.73 turns 3500 when cars are running side by side.
I would do no more than 3.73 with the T350 and 33's for sure. 35's and 4.10 are great with my 4 speed, no converter slip! Like most problems, how much money do you want to spend? Re-gears cost $500 if you do it yourself and more like a $1000 if you have to pay to have it done. The TH700 swap is probably a $2000 swap after you get the driveshafts shortened. So... What are your future goals/plans and how much coin do you want to drop? Once those questions are answered you can get a better idea on what you should do.
#15 | |
Re: 3.08 to 3.73?
Using the .70 OD gear to figure. At 65 I am currently turning 2800 which puts me right at 1960 for OD rpm. At 55 it would be down at 1645 and certainly could be a problem. I think you could avoid it by staying out of overdrive manually unless on the freeway. Last edited by AlaskaMatt; 06-11-2010 at 08:01 PM. |
#16 | ||
Future TOTM Winner
Re: 3.08 to 3.73?
#17 |
Re: 3.08 to 3.73?
Tire height is a good start for calculators, but what you really need is the rolling circumference of the tire, and if you ever watch top fuelers, you know that tire growth has to be figured in! Admittedly it's nothing like that with a street car, but big tires run at lower inflation levels (I run my Wrangler II's at 24 psi which even then has them wearing towards the middle). So you have the inaccuracy of a stock speedo (possibly REALLY off now that tire and gear changes might have been made), any error in whatever tach you may be running. When you combine each of these errors, even if they are small, you get a BIG error in the end.
#18 |
I'm a poor spectator
Re: 3.08 to 3.73?
That sounds like the thing to do IMO.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
#19 |
Re: 3.08 to 3.73?
what is your goal for the rig? Are you talking a commuter back and forth on the highway? A vehicle to put around town in? A trail rig? Or a combination of all 3? I am running a 465 with 4.56 and 36" tires/ High Way speed for me is limited to 65 as it is the speed limit. At 65 I am running around 3,000 rpm. Of course it was not built to run the high way, it was more for trails. So the little bit of high way I run is not a big deal since it is usually getting to or from the trail.
Confidence is the feeling we have before we fully comprehend the situation |
#20 |
Re: 3.08 to 3.73?
I'd say my goal is a combination of all three. It's my daily driver and will stay that way for at least the next two years. It's kinda a street queen. I've been cleaning it up for awhile. I take it on the trails but nothing serious. I'm getting a camping trailer in the next couple of weeks so I'm going to need it to be able to pull 3000-3500 lbs a couple times a month without issues, which I know the current 3.08's are going to give me problems. So, I'm looking for a nice median. I will probably always stay with 33's, but have been thinking of putting in a 700R4 for awhile. I know if I go higher than 3.73 I need OD if I want be okay on the hwy. So my delimma is basically do I put 3.73s and eventually add the OD or do the 4.10s and put the OD at the same time. I'm not going to change the axles twice.
#21 | |
Re: 3.08 to 3.73?
