Moderator
![]() Join Date: May 2007
Slip yoke on a TH400
I am at the point of putting in a driveshaft on my SWB project truck, and was wondering how much "slip" is needed on a TH400 mated to a 402? I have a factory 2 piece driveshaft from a SWB parts chassis that I mocked up (This is the correct TH400 yoke). I measured and there is 1 3/4" before the yoke bottoms out on the tailshaft housing. Here is a pic to illustrate. Yep, I plan on replacing the u-joints too
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Re: Slip yoke on a TH400
If you are using a two piece shaft, the front section stays static and is located by the carrier bearing. The back section slides on the spline joint mating the two pieces as the axle moves up and down. Therefore, I don't think you need much travel for your front (transmission) yoke. I had about 3/8" on my 200 4R install and it seems to be fine. Someone else I'm sure will pipe in.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
Rottenwood Garage Member
I think they say 3/4 to 1 inch of travel, however I doubt 1 1/4" would be a problem.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
#4 | |
![]() Join Date: Sep 2009
Hope that helps Paul and Jason
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
Moderator
Well, it looks like I am good to go then
![]() The carrier bearing has some adjustability as to where it mounts on the x-member. I had it in the "middle" in this pic. I can slide it forward a small amount, and that would give me exactly one inch of travel. The slip yoke has no wear on the outside and it drove great with no driveline vibrations when it was in use a few months ago on my LWB truck. Thanks for the input guys!
Ledd,I forgot to tell you 402/400 is music to my ears
Moderator
Me too
