Old 05-29-2010, 09:10 AM   #1
JoeKan
JoeKan's Avatar
Door/Window handle remover
Does it take a special tool to get these handles off? Just curious, I'm afraid I'm going to break something by trying to pull it off.
Thanks,
Joe
JoeKan is offline   Reply With Quote
Old 05-29-2010, 09:18 AM   #2
72freak
Rottenwood Garage Member
72freak's Avatar
Re: Door/Window handle remover
Thanks,
Joe
Yes....there is a special flat tool you can get at any parts store or you can use a small hooked tool or a small flat screw driver. You are shooting to get a small horse shoe looking clip out of the handle. BE CAREFULL not to loose the clip. If you have to buy a replacement they SUCK!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 05-29-2010, 09:39 AM   #3
JoeKan
JoeKan's Avatar
Thank you.
Joe
Old 05-29-2010, 02:26 PM   #4
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Thanks,
Joe
In a pinch, you can take a clean shop rag and wrap it around the handle shaft (between door panel and handle) and pull the rag around and out.The little ears of the clip will get caught in the rag and will usually pop right out.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 05-29-2010, 03:10 PM   #5
big mike71
big mike71's Avatar
When you go to put them back on just put them on the handle and push it onto the stud. It will snap into place.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 05-29-2010, 06:18 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
All good advice above.
This is the tool I use... cheap to buy, easy to use.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 05-30-2010, 10:26 AM   #7
bigsnookmaster
bigsnookmaster's Avatar
I have the tool, but usually use a small piece of coathanger with a little hook in the end, reach behind the handle, grab the clip, give a quick pull, and they usually pop right off.
bigsnookmaster is offline   Reply With Quote
Old 05-30-2010, 02:56 PM   #8
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Those things are a pain, but I can usually get them with the small flatblade screwdriver method.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 05-30-2010, 06:07 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I have done that several times, and while I always eventually got it to work (and only lost a few spring clips), I finally got the tool I posted above. It is soooooo much easier.
- Mike -
RIP El Jay
Old 05-31-2010, 07:01 AM   #10
72freak
72freak's Avatar
Agreed...the tool is the way to go and once you figure out how to use it correctly.....its so quick and easy and rarely does the clip come off the handle.
Old 06-01-2010, 11:16 PM   #11
RustyDan
RustyDan's Avatar
Hey how about the skinney low down on "Quality" inner window / door handles.?!?!
Convienence parts store knobs/handles are junk.
"Do not follow where the path may lead.
Go instead where there is no path and leave a trail."
"SEMPER FI"
Never retired-Always a Marine
'72 C10 Longhorn-very daily
'86 C10 Van (mothballed)
previous; '65 C10 shorty
& bunches of M/C's
RustyDan is offline   Reply With Quote
