Old 05-29-2010, 11:34 AM   #1
rhodog77
rhodog77's Avatar
frame question......s10 swappers
hey guys,
how much, if any, did you guys cut off the rear frame rails?
thanks
"Get Busy Living or Get Busy Dying"
1970 P10 Stepvan
rhodog77 is offline   Reply With Quote
Old 05-29-2010, 01:00 PM   #2
Thadious
Re: frame question......s10 swappers
I just cut mine yesterday to finally mount the box. I started with an extended cab, so not sure if the length of the frame rails were different than the standard/long box, but I only ended up removing about 1/2" to get the rear cross sill to miss the frame.
Cheers,
Ted.
'51 Chevy Build - In the design stages
Aut viam inveniam aut faciam - I will either find a way or make one.
If you don't have time to do it right the first time, when will you...
My new build - https://67-72chevytrucks.com/vboard/...70#post8958970
Thadious is offline   Reply With Quote
Old 05-29-2010, 05:13 PM   #3
Dan Bowles
AD Addict
I did an X cab on a '54 and cut nothing off. Still have about 1/2" clearance. I modified the frame to be a 117 or so wheelbase.
What are you guys that use a LONGBED frame doing? There are 16" of frame behind the rear shackle mount where the X cab has 10".
Dan Bowles is offline   Reply With Quote
Old 05-30-2010, 10:24 PM   #4
Dan Bowles
AD Addict
Crickets???
Old 05-30-2010, 10:35 PM   #5
waybad
waybad's Avatar
post up some pictures of these swaps...
waybad is offline   Reply With Quote
Old 05-30-2010, 11:01 PM   #6
Dan Bowles
AD Addict
There are tons of pictures out there, just need someone to come along and give an idea of how much they cut off the back. Take a look at his sig line, its got a link to his photo album.
Old 05-30-2010, 11:27 PM   #7
BlueJeep
BlueJeep's Avatar
I used an extended cab frame with a long bed (AD), and didn't cut any off clearing everything fine.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 05-31-2010, 09:12 AM   #8
rhodog77
rhodog77's Avatar
Hey Dan,
I heading down to Atlanta in a few weeks to pick up my box. I will post some pix once I set it down on the frame. Sorry we didnt get the anwser we were looking for.
brian
1970 P10 Stepvan
Old 05-31-2010, 01:01 PM   #9
Dan Bowles
AD Addict
Raining like mad here so I haven't been able to get the S10 mounts cut off of the frame so I can set my cab on. Once I do that, I'll know! Like I said, the '54 on the X cab is about 6" shorter than the long bed. I'll have to decide how low I want the bed on the frame and then I'll decide what i want to cut off. The "splitter" bed is different from the "cyclops" (47-53 vs 54/55S1) but the cross members look to be in the same place. I think I'll end up needing to cut off about 4-6".
Old 06-02-2010, 10:02 PM   #10
Dan Bowles
AD Addict
Well...it is later in the week so I thought I'd try to bring it back to the top to get an answer for those of us using a long bed frame.
Old 06-02-2010, 10:45 PM   #11
jeffs51chevy
jeffs51chevy's Avatar
Ok, ok, I'll answer. I used a long bed regular cab and cut 7 1/2 off the rear rails. I ground out the rivots holding the rear cross member and moved it forward to keep everything proportionate. Let me know if you need more info.
Jeff
jeffs51chevy is offline   Reply With Quote
Old 06-03-2010, 06:30 PM   #12
Dan Bowles
AD Addict
Thanks Jeff!!
And for those asking for pictures: Here's the X cab shortened 5 1/2" 327 5 speed.
And my buddy's beater.
Old 06-03-2010, 08:32 PM   #13
chevy49
chevy49's Avatar
nice 54 dan and i like the car also.i cut off aprox 6 in
chevy49 is offline   Reply With Quote
Old 06-03-2010, 09:40 PM   #14
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Nice freakin shop. The f*** is cool too.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 06-04-2010, 10:33 PM   #15
Dan Bowles
AD Addict
F what?? He's running a stroked Corvette motor with a Richmond 5 speed in that Snake! 383 and 3 pedals.
Exhaust is on the truck, Sins of Steel (the old Billetproof Detroit show) in the morning for us and Bill leaves at 3 am for Power Tour!
Thanks for the info on the frame cut off, guys. I'll probably start with the 6" and trim later if I need to. Depending on what we have time from, I'm going to try to get my cab mounts set up and maybe even cab it.
