Old 02-13-2003, 10:52 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Question shift light
I bought a stand alone shift light from summit made by PRO-FORM ....I am having a problem with the shift light stayin on ?????It worked the first couple of days and then bam it just stays on when ever the key is on......Any ideas?????? OH the power wire is hooked to the ignition fuse on the fuse box..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-13-2003, 10:57 PM   #2
Jackal2k9
Jackal2k9's Avatar
i have found taht often times if you just hit lights with hammers they will go out. we turned a honda civic into a oval racer once check engine would turn of so we just took a hammer to it. but that was after it wrecked and rolled down the track. the whole 500 dollar investment out the drain. not bad for a summer of 1/8 mile racing.
Jackal2k9 is offline   Reply With Quote
