Old 05-29-2010, 04:02 PM   #1
BossHogg69
motor exploder
BossHogg69's Avatar
Hydroboost brake setup questions!
I have a chance to get a hydroboost setup from an '82 1 ton dually. I have built a solid roller cammed 468 BBC for my '69 shortstep (in sig below) and the hydroboost will afford me the luxury of not having to worry about vacuum for power brakes. Here's my setup so far, I'm just wondering if anyone has any experiece or can shed any light on this mix of parts:
I'm using '73-up CPP spindles with drilled slotted 1.25" rotors, POL D52 style dual pistons calipers in front. In the rear, I have a 12 bolt rear with Glocks' adapter brackets using '97 Camaro rear disc calipers (single piston PBR) with '96 Impala drilled/slotted rotors.
For the engine, I'm using a serpentine setup from an '88 dually (7.4L, Mark IV) and I have the pump and all the accessories from this setup. Can I use the hydroboost from the '82 dually with the serpentine style power steering pump? Would I be better off finding a hydroboost setup from an '88-90 dually instead? I understand this may be a question better suited for the 73-87 section, I just wanted to see if anyone here could shed any light on this. Thanks in advance for any help offered.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
454, 7.4, dually, hydroboost
