Old 05-29-2010, 07:53 PM   #1
VA72C10
VA72C10
VA72C10's Avatar
Temperature gauge hookup....quick question
I took off some aftermarket temp gauges. Wanting to wire in the factory temp gauge in the cluster I restored and added a tach to.
My question....does the line go from the temp sensor to the top stud or the bottom? I assume the bottom then is the ground? Just want to make sure before I short out the gauge or the printed circuit. thanks.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-29-2010, 10:07 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Temperature gauge hookup....quick question
well, I'm gonna try it the way I guessed and see if that works....
Old 05-29-2010, 10:13 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
BTW I ran a search and checked the FAQ and the wiring diagram is gone...
and the ones I've found don't show this.
Thanks!
Old 05-29-2010, 10:17 PM   #4
68 Stepside
huh?
68 Stepside's Avatar
The temp sender is tied into the gauge cluster via the factory wiring harness. I don't have the schematics handy, but you might damage the temp gauge if you try to hook a wire straight to it, I don't know.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 05-29-2010, 10:39 PM   #5
VA72C10
VA72C10
VA72C10's Avatar
thanks for stopping me. I'll look at my blazer manual's wiring diagram and see if I can figure it out again...
Old 05-29-2010, 11:56 PM   #6
VA72C10
VA72C10
VA72C10's Avatar
I did a few more searches and found the wire for the temperature sender is a green wire. Second on the right from the top left of the two harnesses in the engine bay that connect to the back of the under dash fuse block. That green wire is cut on mine. I assume since the line on the current temp sending unit is a thicker copper line it was mechanical. So I will have to plug that spot and use the spot on my intake that has a plug in it now. I will post pictures tomorrow in case this can help someone else.
Old 05-29-2010, 11:57 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
And I should have figured that the temp gauge was using the harness and printed circuit since it came right down to it....guess my common sense went out the window when I got three hours sleep....
Old 05-30-2010, 12:40 AM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I'm not sure what you are doing but the wire from the sender goes to the cluster plug terminal number 6, and the other wire is the power feed wire from the plug in that feeds all the gauges. It's a printed circuit board and no wires go to top or bottom of the resister. Below is a pic of the back of the cluster and a cad drawing of the circuit. The temp gauge is the second from the right on the lower row.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
