Old 05-30-2010, 12:23 PM   #1
1971ls1longbed
1971ls1longbed's Avatar
CPP rear suspension
I was wondering if anyone has used CPP's rear suspension kit for the 67-72 pickups and if so how good it is, or info on a better kit from another manufacturer
1971 Custom 10 LWB. 461 BBC and built 700r4 to be transplanted
1997 C3500 DRW Ext cab. 454, 4L80E daily driver
1971ls1longbed is offline   Reply With Quote
Old 05-31-2010, 12:20 AM   #2
LEEVON
Moderator
LEEVON's Avatar
Re: CPP rear suspension
Which kit are you looking at? What amount of drop are you going for? CPP's stuff is high quality, if you're going to order make sure you call and ask for Jeff and tell him your on this forum.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 05-31-2010, 02:36 PM   #3
1971ls1longbed
im looking at their entire kit part number 6372TRS-K with 5" springs and a 1" block
Old 05-31-2010, 05:51 PM   #4
jmedero
jmedero's Avatar
in my research I have found it to be a very nice kit, but very pricey. I have two friends that have them installed. I personally like the Porterbuilt kit better. Looks cooler and has the drop built into the rear arms so no need for a block. And it looks sweet.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 05-31-2010, 08:27 PM   #5
1971ls1longbed
so the porterbuilt kit is good too ok anyone else got any imput
Old 05-31-2010, 09:22 PM   #6
jmedero
jmedero's Avatar
I just like all the adjustment from Porterbuilt. With the adjustments on the trailing arm, and the trailing arm crossmember. You an center that rear wheel in that opening.
