05-30-2010, 03:52 PM | #1 |
3 on the tree
Anybody done a conversion to auto ? Im looking at buying a 69 pickup with a 350 and 3 on the tree. Hate the idea of only 3 speeds. Bad milage on highway? Or whats the opionon? Good like that?
05-30-2010, 03:58 PM | #2 |
Re: 3 on the tree
A TH350 only has 3 gears. Are you looking to put in a 700r4 or comparable?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
05-30-2010, 06:42 PM | #3 |
Re: 3 on the tree
Yes that would be ideal. But which column should I use?
06-06-2010, 01:38 PM | #4 |
Who's got steelies?
Re: 3 on the tree
I just got done putting a 700r4 in my '70 burb. I used a auto column out of a 71-72 truck. All you got to do is adjust the linkage for the extra gear.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
06-06-2010, 03:12 PM | #5 |
Re: 3 on the tree
some of the vendors sell a revised gear indicator for doing an overdrive swap, otherwise i wouldn't even bother if just going to a turbo 350. manual trans already has no slip whereas an auto would need a lockup converter to get true 1:1 in third gear. plus you need all the other bits and a good radiator to handle the extra heat that an auto puts off, yadda yadda yadda...
my 72 burb has the 3 on the tree and i plan to keep it. i'm swapping to a 4.10 third member and have a 406sbc to go in. i like the nostalgia of this trans. i did put in a 4 row radiator to handle that bigger engine and for trailer towing duties and without an auto or a/c to put extra demand on cooling it will be an awesome setup. i eventually plan to upgrade my saginaw to a factory overdrive unit. i do have a spare 700r4 in good working shape (still hooked up to that 406) but i don't want to join the pack. the big engine under the hood with column shifted manual will really throw people a loop! |
06-08-2010, 02:40 AM | #6 |
Re: 3 on the tree
I'm doing this swap right now. Went from a 307/3OTT and I'm going to a 454/TH400.
For the shifter I'm using a B&M Mega Shifter on the floor, I had one in the suburban and liked it so I'm doing it again... |
07-04-2010, 03:34 PM | #7 |
Re: 3 on the tree
you wanna sel all the 3 on the tree parts? i wanna make my 69 3 on the tree
07-07-2010, 09:12 PM | #8 |
Re: 3 on the tree
I had a truck 4 speed and went to a 200 4R. Used a auto column from a truck that had 3 speed auto. You will need an auto crossmember (you will have to remove your standard bellhousing mount crossmember, probably need a new starter that bolts to the block (if yours is a 3 bolt that bolts to the bell housing) a new flex plate, a radiator that has provisions for the trans cooler lines (or a separate aftermarket cooler), trans cooler lines ( the lines for a TH350 or 400 will work with a 200 4R if you go to an OD trans, you'll have to remove your clutch pedal and z bar, get the correct transmission yoke and shorten drive shaft if necessary, wire up the lock up converter (if you do an OD), possibly get a longer speedo cable and the correct speedometer driven gear, and get either an original auto linkage set up or an aftermarket rod with heim joints (I prefer) that costs about 30 bucks to connect the column to the transmission. If your back up light switch is on the 3 speed tranny, you'll have to hook up a combination neutral safety/backup light switch on the auto column.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
