Old 05-30-2010, 05:52 PM   #1
C10Slim
Bed Sills... Am I missing something?
So went to mount the bed to the frame today and somethings not quite right. I got 4 sills lined up but seem to be missing the third from the cab? I tried putting one of the sills across these mounts and the holes don't seem to line up. I put down the square and you can see the holes are at least an inch off. What am i mising here?
C10Slim is offline   Reply With Quote
Old 05-30-2010, 06:04 PM   #2
mbgmike
Re: Bed Sills... Am I missing something?
I think those were used on wood floor stepside. My truck did not even have those from the factory. Just the first set behind the cab. I had to add them for the SWB stepside. I could be wrong but thats what I think. Mine was a originally a Cab and Chassis sold to Texas Gas Company.
mbgmike is offline   Reply With Quote
Old 05-30-2010, 06:19 PM   #3
C10Slim
I thought that too but it looks like the fender stays should bolt up to a sill there. Kind of hard to see but in the 3rd pic bottom left hand corner you can see the stay sticking up with nothing to mount too.
Old 05-30-2010, 07:35 PM   #4
gimmy 64
you need to loosely bolt cross seals to the frame then you have to twist or move bed from corner to corner to line up with holes .put bolts in and then shift bed so its in the rite place for it to line up with cab
gimmy 64 is offline   Reply With Quote
Old 05-30-2010, 09:11 PM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
One Cross Sill is different from the rest. It seems you don't have that differnt one. They would not be from a Stepside because the fleetsides are wider.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 05-30-2010, 09:12 PM   #6
Chevy Fleetside
http://sfbay.craigslist.org/nby/cto/1764533299.html Look at the pictures in the add. If you look hard enough you will see how the front bolts off set eachother.
Old 05-30-2010, 09:15 PM   #7
C10Slim
Well Crud! I don't know where I lost that one along the way. The overall length is the same just the bolt holes are spread further apart. You can tell from the pic they need to be wider, but I have searched all the vendors and they all seem to list the just the regular sills. What the heck am I missing here??
Old 05-30-2010, 10:18 PM   #8
Chevy Fleetside
You might even have one in the wrong place. I would look at my truck but there is so much stuff in the back I dought i will be able to see it. From that picture, it looks like you can move that front one back one and the other up one. If not maybe you have a cross sill from an earlier model. I believe the 60-62 trucks had narrower frames in the rear.
Old 05-30-2010, 10:23 PM   #9
Chevy Fleetside
one more question. Is that a long or short bed?
Old 05-30-2010, 10:29 PM   #10
creep
Registered Loser
creep's Avatar
It should be the cross sill with the bed side braces that support the front edges of the wheel opening. That's how my 63 longbed is anyway. I never noticed the mounts are wider there.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 05-30-2010, 10:35 PM   #11
Rich 5150 69
Rich 5150 69's Avatar
One of the vendors that sells bed kits shows a schematic, just don`t remember who...must be an age thing....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 05-30-2010, 11:23 PM   #12
C10Slim
Longbed
Old 05-30-2010, 11:28 PM   #13
Chevy Fleetside
Old 05-31-2010, 12:16 AM   #14
C10Slim
You can see in the first pic that the two bolts are off set.
The second pic: The wood bed that come with my truck. The second bolt lines up perfectly with the missing sill hole. So there has to be some sort of support that goes there. Also the fender stay must bolt to something.
The third pic: What it also wierd is you have the first bolt exposed which goes through the first sill. Then there is no hole for the bolt in the second sill. Then the third bolt is exposed but there is no sill there.
I am about to just get creative and drill my own holes, it just drives me nutts that I can't seem to figure this one out. I need to see some more pics of completed LWB beds.
Old 05-31-2010, 12:27 AM   #15
Rich 5150 69
Maybe it was a production issue, have you tried swaping ends with the sill..?
Old 05-31-2010, 12:48 AM   #16
Sillyoldman
#16876
Sillyoldman's Avatar
It's the same as the 67-72's. There is one cross sill that is shorter than the others. I'm going to assemble the '63 bed pretty soon. Too late now but I'll mock up my parts and see if I can remember. I think the odd (short) one goes behind the rear axle since it does not mount to the frame.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 05-31-2010, 01:43 AM   #17
Gus63
Had the same problem with my 63. I ended up just drilling my own holes cause I couldn't for the life of me figure out what was wrong.
63 K10 4x4-Little by Little
Gus63 is offline   Reply With Quote
Old 05-31-2010, 09:48 AM   #18
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
here are pics of my 65 long fleet:
first rail -bolted to inside holes.
second rail- just resting in frame, no bolts.
third rail-bolted to outside holes.
there is a 4th too... it is only about an inch tall and runs right in front of the wheel tubs.
behind the axle there were 2 rails and then the rear cross sill, only the second to last rail and cross sill had bolts, the middle one just rests on the frame rail.
I do have a truck that the bedwood knocked out of, I will try to get you an upper pic....
** BTW as far as I can tell all the rails are the same except for that 4th that is not as tall... , they all have 2 holes, and are all tapped for the wheelwell supports.***
Old 05-31-2010, 10:00 AM   #19
jonzcustomshop
1961 crewcab
here is the top side of my 65... front, then rear, only 8 bolts holding the bed on...
Old 05-31-2010, 10:16 AM   #20
jonzcustomshop
1961 crewcab
I just looked at my custom 60, its bed came off of a 61 gmc 3/4 4wd, and all the cross sills seem to be the same as the ones on my 65.
Old 05-31-2010, 10:22 AM   #21
C10Slim
Thanks for the pics Jon! I am starting to think I have some kinda freak truck or something. I bolted up one side just as you described. Go to the other side and I am still an inch off. Could you please do me a favor and run a tape measure or yard stick across those bolts and tell me how far apart they are?
Old 05-31-2010, 10:26 AM   #22
jonzcustomshop
1961 crewcab
...more devolpments...
my 61 cross sills:
all measure from the end to the first hole 16 inches, then 18 inches to the second hole.-all 5 of them.
on my 65 the first 2, and the last 2 measure 18 and 20 inches, but the sill that you are missing, and questioning, measures 17 1/4 from the end to the bolt!
so it is a different piece.
Old 05-31-2010, 10:32 AM   #23
Chevy Fleetside
In that last picture. It looks like the forward one would work but I can't really tell to much from that picture. Most of my bed work has been with short beds. I never really saw how the long beds were done.
Old 05-31-2010, 10:36 AM   #24
jonzcustomshop
1961 crewcab
as for how far apart, center to center the front and 2 rear are 31 1/2 apart on the inside holes, and the 3rd is 37 3/4 center to center on the outside holes.
Old 05-31-2010, 10:46 AM   #25
C10Slim
Thank the lord I am not loosing my mind!!! Can't thank you enough for taking the time to measure and give me back my sanity!
I took some measurments as well. The first pic is the frame holes you can see they are 37-3/4" or so. The second pic is one of the sills. On the widest holes they it is 35-3/4". So about a 2 inch difference.
Now I just need to find one of these wider sills or make my own.
