05-30-2010, 09:25 PM | #1 |
Need some pics of bagged trucks on stock suspension
Ok, I have a 70 swb 2 wheel drive with trailing arms. I can't seem to find any pics on search engine. I would like to see what it would look like with stock suspension bagged with rear c-notch preferably with 20 inch wheels on all fours. Links or pictures and a little about it would be great.
05-30-2010, 11:30 PM | #2 |
Happy to be here
Re: Need some pics of bagged trucks on stock suspension
What do you mean by stock suspension? Are you saying no dropped spindles, or ?
06-01-2010, 07:00 PM | #3 |
ok, guess I wasn't clear. How about 2 1/2 drop spindle with stock control arms with bag in front and for the rear bags on trailing arms with a c-notch installed. "Lucy" is my ideal stance was by N2BILLET I believe, but thought it would be great to get some other pictures.
06-01-2010, 07:25 PM | #4 |
Redefining LowBudget
check my build for pics and some ideas and part #'s you need to drop your truck on bags
my truck is a 70 LWB and all my suspention is stock parts with a 2" C notch
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
06-01-2010, 07:41 PM | #5 |
cool, thanks hottrucks. I'm pretty sure I've seen your build through all the hours spent on here but I'll ck it out again for a refresher.
06-01-2010, 09:11 PM | #6 |
Believe it or not If I had to build it again I could do the suspention in a weekend...I just had to swap out the rear bags and it took me about an hour and a half
06-01-2010, 09:19 PM | #7 |
Pic of my old truck that I sold, had air ride front control arms but everything else was stock including trailing arms. Had a regular c-notch. Rear was actually hitting the bed floor.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 Last edited by Bennett68C10; 06-01-2010 at 09:20 PM. |
06-01-2010, 09:20 PM | #8 |
Official Site Guitar Shredder
2 1/2 drop spindles..Stock lower control arms with plates...RE-7s front bags...Stock trailing arm rear suspension. 3 inch blocks...RE-7s rear bags. Bolt in C-Notch..<welded in.....255/35/20s front..275/45/20s rear......
06-01-2010, 09:57 PM | #9 |
TILT COLUMN GURU
Check out this LINK
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
06-01-2010, 11:38 PM | #10 |
Addicted user
Here's my 2wd blazer with a " ride tech " air kit with their C Notch... I have 3" bellteck spindles on the front too. The front will lay the stock crossmember on the ground without a bumpstop..
Not sure if this helps or not but it shows the frame height kris Last edited by zammer; 06-01-2010 at 11:39 PM. |
06-02-2010, 01:08 AM | #11 |
bad6772, what color is that??, cant decide between a green or orange paint job, liking yours though
06-02-2010, 01:13 AM | #12 |
Just finishing mine up this week ill post some pics - i think its plenty low - the front crossmember is on the ground with it aired out
ill post some pics asap |
06-02-2010, 07:38 AM | #13 |
Hey Bad you don't have a pic of those 3" blocks do you...I heard there is scrubline issues with more than 1.5"
06-02-2010, 09:02 AM | #14 |
I can get one....today....I think its with 15inch tires that I heard the same thing......? ButI am not positive.....Murg its a Stock Gm color that I doctored up some.....
06-02-2010, 09:40 AM | #15 |
see my avatar and/or click on build thread link in signature
06-02-2010, 08:51 PM | #16 |
upper plates, 1 1/2 '' lower cups, 3'' drop spindles, 2 1/2'' c- notch, does push up on bottom of bed some, stock inner fenders front and rear
06-02-2010, 08:58 PM | #17 |
I'd like to know what tire height in front I have 29" and I had to ditch the inners and I havn't even put my drop spindles in yet??
06-02-2010, 09:07 PM | #18 |
Thanks alot guys, great lookin rides! keep the pics coming.
06-02-2010, 09:17 PM | #19 |
Another question? So I'm looking at Mickey Thompson 29X15.00R20LT. My question is what would be the min backspace that I could run on say a 12 in. rim? I'll probably get a 10" rim and have is widened 2-3 in. Rim will come in a 5" backspace (looking at coy c-5's). Is this going to work? Or will I more that like have to narrow rearend?
06-02-2010, 09:24 PM | #20 |
JRods Garage
does adding tubular front lower control arms and rear trailing arms make a difference?
07-20-2010, 09:08 PM | #21 |
07-20-2010, 10:31 PM | #22 |
One day.....
Heres my ride. Bagged all around. Front has 2.5 inch drop spindles, bags and CUT bag cups. Cut off an inch off of them. Might not sound like a lot but makes a big difference. Rear has bolt in c-notch, bags and NO cups, 2 inch lowering blocks. Picture is of truck aired out.
DZL1. |
07-21-2010, 03:33 AM | #23 |
Chevy Truck Addict
Come on Tony... Don't you mean it's my color that you "doctored up". Please give credit where credit is due.
Murgg, the color is an R/M Diamont formula that I picked from their color chips... It was inspired by the stock olive green metallic available on these trucks in the day. Tony added some pearl but from what he told me, he basically used the exact formula that I sent him. Here's mine with a 2" drop spindle and a leaf spring rear end with an axle flip, 3 leaves removed, 1" block and c-notch. Here are a couple of pictures with the suspension "aired out".
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
07-21-2010, 09:34 AM | #24 |
07-21-2010, 02:17 PM | #25 |
Tot Roddin'
Just so you can see both sides for comparison, here's my '69 running a 4.5/6" drop kit:
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
