Old 05-30-2010, 11:15 PM   #1
kanuck
17x8 wheels, will they fit?
just went and looked at set of 4 17x8 chrome wheels that i can get for $80 bucks because the chrome is pealing on all 4, no other damage otherwise.
The bolt pattern is right at 5on 5 and the label gives the offset as +18mm.
Think the name on them is cheyenne.
Measuring at the back of the rim I got 5.5 inches from the backing plate to the outside of the rim.
Wondering if anyone knows if these will fit on my 1984 swb lowered about 3 inches in front. Seems like a fair bit of offset and wondering if they will rub on the inside.
Also will the chrome come off with sandblasting? Was thinking of powder coating them if they fit the truck.
'70 Malibu with 383 stroker/T350
'56 SWB Mercury pickup..under construction
'67 Firebird Convertible...all done stock
'70 LWB 350 on propane...beater
'69 LWB 350/T400 body restored
kanuck is offline   Reply With Quote
Old 05-30-2010, 11:17 PM   #2
kanuck
17x8 rims, will they fit?
Old 05-30-2010, 11:28 PM   #3
slugish
Slugish
Re: 17x8 rims, will they fit?
My 8 in. x 17 in wheels rub my lower control arm on sharp turns . 5 in bs would be better . They will work , but if you dont want the rubbiing , you can grind off some of your lca if they do rub > plenty of the members do this. Oh by the way mine are 5.5 bs also.
slugish is offline   Reply With Quote
Old 05-30-2010, 11:37 PM   #4
463
463's Avatar
Re: 17x8 wheels, will they fit?
http://www.roadkillcustoms.com/hot-r...e-Database.asp this site may help you
463 is offline   Reply With Quote
Old 05-31-2010, 07:47 PM   #5
kanuck
Thanks for the web page and info.
Other question is about cleaning up the rims. Can the chrome be removed by sand blasting? Was wondering about getting them powdercoated.
thanks
