02-14-2003, 12:34 AM | #1 |
Driveshaft angle
I just put in my one piece driveshaft, and it appears like there is a slight angle from the right at the rear to the left at the front. I haven't pulled a tape on it yet, but is the driveshaft supposed to be perfectly straight from side to side? The rear has lowering springs (3"), but measuring from the frame to the inner edge of the tire is about the same on both sides (within 1/4")
Thanks, Greg
69 SWB LT1/4L60E www.classicplace.com |
02-14-2003, 12:46 AM | #2 |
hhmmmm how slight is this angle.... i need to look at mine... mayb your trans mission is moved to one side or your axle mayb? so not the axel. trans? what kind of mounts you have cross memeber? hows it all setup.
tweaked frame.measure frame widths all the way down and make sure its the same then measure "x"'s across symetric areas. make sure thats good. Last edited by Jackal2k9; 02-14-2003 at 12:49 AM. |
02-14-2003, 12:57 AM | #3 |
Fabricate till you "puke"
You might check the diff , to see if the pinion is centered.....Im not sure on the older 12 bolts, but my 69 has a 75 diff(12 bolt) & it appears that the pinion is offset slightly to the right(not centered in the housing)..........crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
02-14-2003, 02:47 PM | #4 |
Out of the carpool lane.
Mine is offset as well.
I've measured from the widest point on tire to frame and aligned rearend using the adjustable tracking bar. I'm pretty sure trans and engine are aligned as well. All this leaves less space on one side of crossmember loop than the other. I only have about an inch on one side of the hole in crossmember.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
02-14-2003, 02:59 PM | #5 |
They should all be offset slightly. Ujoints are not designed to work in a perfectly straight line, but require a little offset in both planes, but as you know, it can be exceeded. 1 deg is minimum and about 5 deg maximum out of phase.
02-14-2003, 03:47 PM | #6 |
That offset is normal and is EXACTLY why the vehicles were engineered with a split shaft. (that, and to ease body twist during heavy loading)
Shouldn't be a problem though. U-Joints provide flexibility for short term suspension deflection but should never be out of line more than a degree or so during steady state conditions. That is what a CV (constant velocity) joint is for like on your front wheel drive vehicles.
'72 GMC C20, "2500 Super Custom", Custom Camper, New 454 '93 K2500 Suburban, Old 454 (157K) |
02-14-2003, 03:58 PM | #7 |
aka Crusher, Crushergmc
As long as the output shaft (trans) and the input shaft (diff) are parallel in the horizontal and vertical planes, you will be fine. Kinda what was stated before
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
02-14-2003, 06:53 PM | #8 |
I appreciate all the help. I won't worry about it.
