Old 05-31-2010, 03:31 AM   #1
scottcorvette
Extra gauges - what size???
I would like to fit some extra gauges to my 454 68 C10.
I like the look of the factory setup but think I would need to change the wiring harness aswell to make it work. Is that the case?
I was thinking about getting a Sunpro retro tach either on the column or on the dash, and some VDO gauges to go in the bottom half of the gauge cluster.
I currently have the standard setup, can someone measure the bottom holes in the 7 gauge cluster so I can see if these gauges will fit into the holes. I would cut holes in the backing plate for them to mount in so they appear to be recessed into the dash.
Scott
scottcorvette is offline   Reply With Quote
Old 05-31-2010, 04:39 AM   #2
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Re: Extra gauges - what size???
Large ones are 5"
center (medium) one is 3-3/8"
small ones are 2-5/8"
Heres the link I got it from hope it helps. http://67-72chevytrucks.com/vboard/s...d.php?t=306796
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
