watts link
Anybody in here running a watts link, I `m thinking of building one and using the rear axle center pin as the pivot point, and making the out board ends adjustable...anybody see a problem with the offset of the locating pin on the axle....?
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: watts link
If you're talking about using the panhard bar stud on the differential, I don't think it will work since it is at a little bit of an angle.
There has been some discussion on here before about Watts links. You might try a search both here and in the suspension forum.
Senior Enthusiast
Re: watts link
This thread may give you some ideas:
http://67-72chevytrucks.com/vboard/s...2watts+link%22 And here's another thread on if this should be the preferred solution: http://67-72chevytrucks.com/vboard/s...2watts+link%22
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Registered Loser
Re: watts link
***************** has a really nice Watts link kit.
http://www.*****************/4-link-k...-universal-kit
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
Re: watts link
Thanks guys, I`m giving this some thought...
