454 Conversion
What radiator did you use and where did you get it
Re: 454 Conversion
rolled with the stock one, along with a 7 blade flex fan....would barely hit 200 degree mark in dead stop and go traffic on hot cali days, ran about 180-85 in free flow and regular street driving.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 454 Conversion
I'm currently using a factory 4 core radiator, with dual electric fans. For some reason it has never done a good job of cooling for me. Hopefully soon I will be installing a Summit universal aluminum radiator and the electric fans.
Re: 454 Conversion
Are both of your 454s relatively stock? Just curious why 1 would work and the other wouldnt. Are you both running t-stats?
60-66 Nut
Re: 454 Conversion
Mine is just warmed up a little, and yes I do run a thermostat.
Re: 454 Conversion
mine was pretty much stock...performer intake, 750cfm carb, full length headers into lake pipes, edelbrock water pump, edelbrock fuel pump, flex fan, no thermostat.
Re: 454 Conversion
I'm running a 396 with a 4 core stock radiator, 180 t - stat, performer intake and comp xtreme 4x4 cam. It will hit 200 on the hotest of days (108) around here without worry of getting hotter. I do want to get a better shroud, fan and clutch to keep it a little cooler though. If all goes well, the 454 is going in very soon.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
Re: 454 Conversion
In our 65 burb build we are useing a U.S radiator triple flow and the motor Is built
454 bbc we will be showing pics of the motor in our build on thursday. Justin |
Re: 454 Conversion
4 core isnt necessarily stock though is it? Who do you guys recommend to get a 4 core stock radiator from?
Re: 454 Conversion
